Did the drivers seat mod
I added 2" foam to the drivers seat today for needed comfort. See this link for the how to:
http://www.diesel-max.com/3rdgenfrontseatfix/
Couple of things to add:
1. 1" foam is probably adequate (unless your a big boy).
2. An air ratchet with 1/2" deep socket is the ticket for the front seat bolts.
3. I cut the foam size to 14" x 16" and it fits well. I cut the carpet support to 12" x 14".
4. The springs that hold the support grid are very strong. It's tough to pull them with pliers so the better way is to use a screwdriver under the grid bar and hook the spring with the tip. Then using leverage pull the springs in place.
That was the best mod I've done to my truck - even better than the gauges, because now I can actually drive the truck without it hurting my hips or making my legs fall asleep.
I did the same fix on my '06. Although the padding hadn't broken down, the curvature of the bucket seat didn't fit my "bucket". On my last long trip, I found my legs hurting and burning and couldn't squirm around enough to get comfortable.
Instead of upholstery foam, I bought one of those pads used under sleeping bags from WalMart and cut it to size. I followed the same process as outlined above and found it to be a fairly straightforward project.
I haven't made a lengthy trip yet but it seems to fit better so far.
Dan
Dan
After doing the seat on my 05. the first trip I took felt like I was riding on an air seat.
I did send a thank you to the author of the repair and told him what a great idea it was.
Thank you so much for posting this up, my seat realy aggitates me aswell on long trips. I just can't seem to get into a comfort zone.
I just might go out to the local furniture store and cut out a piece of their memory foam beds on display, im sure they won't mind
My truck is a basic model, no power nothing. So my seats cannot be raised up/down or anything else. My girlfriend is pretty short and she has a very hard time seeing over the dash, lol. Maybe i'll do this to both driver and passanger side so she can see out the windshield when drivng down the road.
Yea I don't know if i'll go 2" thickness because I can see just fine over the dash & I think that may be to thick/akward feeling. I'll try an 1" at first. It's atleast gotta feel better than the stock seat foam.
I just got back with three stitches, a 1/4" piece of tendon removed, and a tetanus shot -- pliers slipped off one of the springs and the force rammed my right ring finger into the back of the seat base. I cut it to the bone near the knuckle, tore out a little bit of tendon, and had to control bleeding while trying to put it back together to go for stitches.
Needless to say the mod is not complete. I will attempt again tomorrow depending on how the finger feels.
Dang, that sucks Festus. Are you doing ok? You didn't drive your truck to the hospital did you?
Thanks for the heads up though, i'll be sure to use a small pair of vice grips.
Actually, the only thing that needs to be unbolted is the seat from the frame and disconnect the wiring if you have power seat.
Other than that, its pretty much straight forward.
I went with 2 in foam because Im a big guy and figured the foam would settle and conform to me as I drove.
