Defroster not working???????
Old Feb 14, 2007 | 06:30 AM
dbossdiesel's Avatar
Unhappy Defroster not working???????
This morning I noticed my heat selector is not going to defroster. It works on floor and vents but I switch it to defroster and it stays on floor. Is it the switch (selector) or a vacume line? Thanks!
Old Feb 14, 2007 | 09:13 AM
mule3010's Avatar
Me too. I've noticed that if you turn the fan off for a while and run it sometimes it will start working again. It is real annoying though.
Joe
Old Feb 14, 2007 | 09:27 AM
SSminnow's Avatar
Broken blend door. There is a TSB on it......I am fixing mine right now
TSB 24-004-03
Look for my thread on this "A/C controls."
Old Feb 14, 2007 | 11:05 AM
Thanks guys! Well, its a blizzard out right now ao I aint going out there to check! But I will do so in the future! Thanks again!
Old Feb 14, 2007 | 11:38 AM
azwolfman's Avatar
Just had my 2005 at the dealer last month for this problem. They had to replace the Control Air motor, part# 55056321-AE. Thank God it was under warranty!
Old Feb 14, 2007 | 09:39 PM
SSminnow's Avatar
The part numbers on my 03 are:
5127758AA
5019632AA
5073964AA
68004226AB
Old Feb 15, 2007 | 03:26 PM
Hey SSminnow? Thanks for the part #'s but, wich one is it? Unfortunetly my truck is no longer under warranty.
Old Feb 16, 2007 | 08:19 AM
SSminnow's Avatar
I am replacing ALL of them since I am going to be in there, might as well.
5019632AA is $5.48
68004226AB is $16.60
5073964AA is $22.56
5127758AA I have not bought yet, was told it is $43, but dealer told me $96
Once I get a $43 pric I wil buy that one as well.
501 is the coupling
680 is the housing
507 is the door
512 is the HVAC
Also, the FinTemp Sensor is prone to breaking, BUT, I found out it is part of the Evaporator
I see it like this: Going through all of this labor, my truck has 130K+ on it, not only am I thinking of replacing the evaporator with Fin Temp Sensor, but ALSO the heater core, that way I will not have to worry about any of it for a LONG time since I plan on keeping this truck 'till the cows come home
Old Feb 17, 2007 | 03:56 AM
Ok SS I'm pretty much the same way. I have to the ball joints on the drivers side but I'm waiting for my income tax check so I can do all ball joints and u joints etc...... Might as well I'm gonna be there! LMAO! Thank again!
Old Feb 17, 2007 | 07:45 AM
SSminnow's Avatar
It is funny, BUT, to pull out the whole dash, you might as well. Now, if my truck only had say 40K on it, then probaly not. But with 130K, and with my luck, I would no sooner get everything back together, and the heater core would start leaking
With your ball joints, if you had to pull the WHOLE front end off, you would be silly to not replace all the Ball Joints while you were there. But since you can do one side at a time, you can afford to wait.
I look at it like this:
If say you had an automatic, and second gear was slipping. Tranny is pulled apart and you find 2nd gear clutches worn. Would you replace JUST the 2nd gear clutches???? Nope, you would freshen the whole tranny up. Or, you would be crazy not too.
The dash is not THAT severe of an example, but a pretty good analogy.
And besides, if I have to remove the dash for a $16.00 part, and a $5 and $22 part are sitting right next to it, you are darn straight I am replacing them.
Now, replacing the Evaporator and Heater Core IS taking it to the extreme, I agree. But once again, with 130K, I plan on keeping this truck for over 200K, more than likely 1 of the 2 (if not both)will leak between now and then. I only want to pull the dash apart ONE time during my ownership of this truck
Old Feb 18, 2007 | 08:34 AM
I aggree! The defroster isn't at the top of my list but its on the list! If I let the truck idle for 20 mins it melts everything anyways! Front end and right rear caliper is on the top of the list!
Sleigher
May 4, 2017 02:12 PM
lawnman757
May 31, 2008 09:50 PM
Hoss
15
Mar 22, 2006 07:32 AM
AMERICANPIE
Dec 22, 2003 04:20 AM
Nuttymopar
Nov 12, 2003 12:56 PM
