Defroster not switching
I am starting to have trouble with my defroster in my truck. It seems to not want to switch from vent to heat or defrost. If I get lucky and hit a bump it will sometimes switch. Does this sound like the blend door or do I have electrical problems? Thanks in advance ffor the help
Do you hear it switch? Any noise from the dash area when it does switch? eaither the heat/ac head is bad(dash conrol) or a door in the dash is broken or binding.You need to narrow down which issue you have.
Mine does this also, in the winter, I have figured out to just leave it on the defrost setting all the time. If I forget, it will switch over after the truck warms up if I switch the fan on and off a few times. I have not figured out the problem yet but is annoying especially with frost on the windows.
Guys I am having the same problem. I fought this problem all winter. When I was driving in a rain storm late this spring I noticed that when I turn the a/c on it will switch from the vents to defrost. Give that a try. Maybe someone with a little better understanding of these systems will be able to give us more info with this discovery that I made.
dbossdiesel
Feb 18, 2007 08:34 AM
patdaly
Jan 25, 2007 11:56 AM
