Control Arm change need experienced advice
Old Dec 20, 2009 | 06:20 PM
1772johnboy's Avatar
Needing some advice on lower control arm swap. Installing Carli arms. Have changed pass. side upper, since they are 1/2" longer I raised axle from under lower arm front bracket which rocked the housing slightly allowing bolt holes to line up nicely for the top. How do you move the axle, (have not taken bolts out yet as they seem pretty tight as in a bind) to get the bolts out and the longer arm in and bolts in the bottom arm? The truck is on the floor as the pro's at Carli said that is the easiest way to do it. They also said to use the caster/camber adjusters to push the axle forward for the bottom arm, but it seems to be pretty tough to turn and I am reluctant to get ugly with it. Im am working on it now and looking for a way to rock the housing to allow easy removal of bolts then a little further to throw in the longer arm. Any ideas will be much appreciated. Open beer getting warm, back to the grind. Thank's, John
Old Dec 20, 2009 | 06:25 PM
ZacMan5712's Avatar
i left mine on the floor. no jack no pulling wheels. just do one side at a time. i had some help just braced myself and pushed on the axle w/ my feet as someone slid a bolt in. the old ones came out no problem.
Old Dec 20, 2009 | 07:04 PM
bansh-eman's Avatar
Almost everything I have done under my truck required me to use my legs to move bolts. I would thnk your going to have to do the same thing with the axle. Get up against something solid and push against the axle an have someone slide that baby in there.
Old Dec 21, 2009 | 04:06 PM
jd1515's Avatar
I have used a ratchet strap on my Jeeps control arms. Just put the one hook on either top or bottom of the axle depening on which way you want it to rotate. Take the other side and hook it to the frame some how.
KS12V330
Jan 6, 2008 09:51 AM
feets
Jul 31, 2007 07:24 AM
PWT05Dodge
May 26, 2006 06:45 PM
rkelso98
Jan 30, 2003 05:07 PM
