cold weather High Idle -removable?? DRL?
Is the high idle removable from the BCM and can the daytime running lights be activated thru the BCM? i got the rolling door locks taken out, but they said the others are not possible, but thought i read here that it was? thanx , crossy
There is more adjustability in the 2006+ trucks... but the factory fast idle is not disable-able. Its there for a reason, why would you want to turn it off?
As far as DRL's you should be able to tell the truck it was exported to Canada and DRL's will work... *should* (I remember seeing the option when I was messing with a DRB III on my 05)
Yes helps the engine warm up sooner, or stay warm when idling in cold weather. The increased load also decreases cylinder washing by increasing cylinder pressure. All trucks have it enabled from the factory.
~32*F and low coolant temp after 2 minutes of idling the rpms will increase to 1000 until you are warm (180*), tap the brake, or put it in gear.
~15*F and lower it goes to 1000 rpms as soon as you start the truck until you are warm (180*), tap the brake, or put it in gear.
Why do you feel its unneeded? If you idling that long then you need it to keep cylinder temps up, to keep the cylinders from washing.
But if it really annoys you then put a stick between the seat and brake pedal.
The factory high idling can not be turned off, you can turn off the high idle controlled through the cruse control. FYI they made sure you can't turn off the factory high idle for a good reason, its there to help prevent cylinder wash when it gets cold.
I downloaded SJ67V603BR20ME.7z,uncompressed it, and uploaded that smc file to the smarty. Then did the 'default' basic upload to the truck
Smarty J67 Ver. 6.03B, Data: J20ME
REVO software
Mar. 23, 2010
5,061 KB
I just put it on there this past weekend, its the latest ME file
REVO software
Mar. 23, 2010
5,061 KB
