A/C selector not working
Old Aug 22, 2006 | 02:10 PM
jesterstruck's Avatar
Well it is stuck on the face selection. I move it to defost or feet and nothing happenes. Everything else works but that. Anybody know if it is a vacume system or a electical.
2003 6sp 4x4. 75k on her
Thanks
Old Aug 22, 2006 | 04:59 PM
shifter's Avatar
My 06 is having the same problem, goes in thur. will let you know what they say. Only 6000 miles! I see similar problems with the hvac system on these boards, pretty sad.
Old Aug 22, 2006 | 06:09 PM
lehall's Avatar
jester it a vacum problem.I have a 2000Ram 5.9.Look for a small canister with a vac hose in top and out bottom.It should be about the size of a 35mm film canister or smaller.Mine is located near the firewall on the left side of motor.hope this helps.you can get a smaller replacement at Napa.
Old Aug 22, 2006 | 10:38 PM
FMB's Avatar
FMB
Thanks
Your '03 works on electrical, not vacuum. Check out http://www.hemitruckclub.com and look in the left hand collum for the Shop Manual for your truck. It is a hefty download though, about 84 Meg or so.
Good luck.
Old Aug 23, 2006 | 11:09 AM
Spooler's Avatar
Yeap, it is electrical. Sounds like an issue with the Mode door. May be the motor or a broken door.
Old Oct 22, 2006 | 02:22 PM
bcfirefighter's Avatar
i have exactly the same problem and the same truck, plz let me know what you find out
Sleigher
May 4, 2017 02:12 PM
toolhawk
May 1, 2012 04:18 PM
jesterstruck
Oct 15, 2006 11:54 PM
Evildiesel
Aug 16, 2003 09:52 AM
