A/c issues
Old Jul 13, 2014 | 05:23 PM
OMGDODGE's Avatar
A/c issues
So living with the Tach issue. New problem A/C stops putting out cold air so I took it to dodge, codes showed high amp from compressor so the computer turned off A/C compressor, after clearing codes A/C work fine. Went on Vacation now, 3000 miles from home A/C quits again, I take it to Dodge they tell me bad computer, $1250.00 later A/C working got me all the way home, then two days later A/C quits blowing cold air again I have check and the compressor clutch is not kicking in again. When it works it works well and will freeze you out. I know there is no refrigerant charge issues. I am a Trained A/C Tech. I asked the deal to change the clutch when I took it to them, they promised me it was the CPU as there were other funky codes. now I am 3000 mile from that repair shop. Go Figure) I am getting ready to do one of two solutions, 1. I am going to replace the A/C clutch and have the codes reset. then if it fails 2. I am going to remove the A/C system from the CPU and let it run stand alone.
Any one else been through this. and did replacing the clutch work.
Old Jul 14, 2014 | 06:59 AM
MikeyB's Avatar
What year model is your truck?
Check the wiring harness next to the AC compressor. Make sure it's not chaffing. There's been a few instances with chaffing causing issues with the transducer.
pappyman
Dec 11, 2002 03:37 PM
crossy
Dec 8, 2002 05:14 PM
crossy
Dec 5, 2002 10:42 AM
TXTad
Nov 11, 2002 12:39 PM
