brake controller?
brake controller?
Does anyone have a picture of where the brake controller plugs into on a 2004.5 Cummins?
The plug has a positive on one end, and a negative on the other end, and 2 wires in the middle.
I was looking forward to installing the brake controller this weekend, but my directions aren't very good
thanks in advance
thanks in advance
If you do not have the Dodge Harness from Tekonsa (owns prodigy) I would spen the money. If there is an RV place near you that carries the Prodigy they will have them. The part number is.... well I can't find my box. I will look it up and edit my post.
EDIT: 3020-P http://www.tekonsha.com/bch3020.html
Hub
Hub
The plug is underneath the dash, just below the parking brake release, against the outside fender. In the picture above, he has his brake controller plugged into the blue female plug.
Yours will be blue also - with nothing plugged into it - right next to that large white bus connector.
You do have the tow package?
Hub
Here is a link to the origional picture that has not been resized. It 2MB. I don't want to post it here because it wastes bandwidth.
http://www.roostingthedunes.com/Temp/IMG_1455.JPG
Hub
Hub
OK fellas, I found the plug, after some digging. thanks a lot
now the next dilemma--where to mount the brake controller?
I dont want anything in the way of my legs, and the steering wheel is kind of in the way if you want to mount it up high on the right or left hand side
again, thanks, I definately could not have found that little bugger by myself
I have thought about mounting it in the cubby slot in the dash for easy access but I use that slot of for the cell phone and MP3 player.
Hub
i mounted my hayes on the floor console all the way to the left in front of where the manual t-case shifter would be, allowed me to completely hide the wires and keep the knee panel clear. used two sided tape so i didnt have to drill holes and could be moved later if i didnt like it there. you can kind of see it here:
Busboy
21
Jun 10, 2011 11:39 AM
kingofdodge7131
Jan 31, 2010 10:15 AM
