Brake Change Question
Old Apr 4, 2010 | 07:05 PM
Pliny the Elder's Avatar
Im in the process of chasing down a squeeking noise, and I went to take the calipers off and cant get them off, *** am I missing, I took the 2 bolts the hold the caliper on the bracket. Do you have to the bracket that holds the caliper on also, b/c I see its holding some clamps that hold the pads?
Old Apr 4, 2010 | 08:22 PM
Well nevermind, it took a big pry bar, but while reinstalling the caliper the the bolt that holds it on broke in the bracket I was even torquing it down either.
Old Apr 4, 2010 | 08:44 PM
06RAM2500's Avatar
I have to do mine yet, so look for a write up soon.
Old Apr 4, 2010 | 08:58 PM
Totallyrad's Avatar
I did a right up with pictures on the 3rd gen dually rears, it's in the WIKI. I've seen one on the 4wd fronts, but I don't think it made it to the WIKI yet.
Old Apr 4, 2010 | 09:02 PM
cincydiesel's Avatar
Did you use a clamp to compress the caliper before removing?
Madhat has one somewhere. I seen it awhile ago on the archives.
Old Apr 4, 2010 | 09:19 PM
No, just a pry bar, once off it was easy to put back on, but like I said Im screwed due to a broke bolt.
Old Apr 4, 2010 | 09:25 PM
Totallyrad's Avatar
If you happen to be working on the rear, I believe it's only 2 bolts to pull the entire bracket so you can get to the broken bolt more easily. Just remember to hang the caliper on some wire or zip tie it up. Don't let it hang on the flexible brake line.
bradshaw106
Nov 27, 2009 12:06 PM
dodgebowhunter
Jun 29, 2009 08:59 AM
jmccart
13
May 27, 2009 09:45 PM
markm4
Jul 29, 2007 11:16 AM
doitl8r
Jun 4, 2004 11:14 AM
