Battery replacement- how to
Old Nov 19, 2014 | 10:34 AM
FROSTY1's Avatar
Have to change both batteries in 05 2500. Batteries sit in box- no handles on battery. any trick or method of grabbing battery to remove? Or is a tool needed to grab the battery?
Thanks
Old Nov 19, 2014 | 02:02 PM
NISMOramAE86's Avatar
I replaced mine..2? years ago, same truck. I dont remember using or thinking i needed any special tools. They are heavy, yes. A stool beside the wheel and one foot on the fender for leverage i think was how i did it.
Old Nov 19, 2014 | 02:37 PM
shep1's Avatar
Gloves, old cloths and muscle. Just replaced mine last week.
Old Nov 19, 2014 | 03:01 PM
BigIron70's Avatar
Cummins Guru
Disconnect ground cables on both batteries first. Remove all battery holddown bolts. They do make battery carry tools any auto parts store stocks them. Or do what I do in a pinch, large pair of vice grips. Clamp on to battery post, just be careful not to short across the battery posts.
Old Nov 19, 2014 | 04:45 PM
verdesardog's Avatar
DO NOT lift batteries by the posts, that can cause internal problems.
Old Nov 19, 2014 | 05:33 PM
BigIron70's Avatar
Cummins Guru
I lift by posts only when replacing the battery, you are right it will damage battery. So don't lift by posts if you will be re-using battery.
top tool lifts by posts
bottom tool does not
Old Nov 19, 2014 | 05:43 PM
whiteeye42's Avatar
who cares they are old batteries anyway this is what you need
Amazon.com: K-D Tools 205 Battery Carrying Strap: Home Improvement Amazon.com: K-D Tools 205 Battery Carrying Strap: Home Improvement
i bet you could get it at any auto parts store
Old Nov 25, 2014 | 12:22 PM
GSW's Avatar
GSW
Another tip that might help to keep the cables out of the way and make sure they don't touch the wrong thing, is to zip tie them off in safe locations. It gives you more room to wrangle those heavy batteries out.
Also, if it's the stock battery tray, don't forget to remove the small wedge at the base of the battery first. Otherwise, that dude is not gonna budge.
Rancher99
Apr 18, 2011 09:46 AM
jesussaves
Nov 7, 2010 06:55 AM
EdmontonCanada
Oct 10, 2008 11:37 AM
taildragger
38
Dec 19, 2006 09:49 AM
planejane
Aug 23, 2004 03:17 PM
