backup lights out-no trouble found
Old Apr 26, 2006 | 10:54 PM
jdog's Avatar
i have a 2003 qc dually 4x4(5 speed) with a problem. after buying a used trailer and hooking it up to the stock plug on my truck for about 6 hours, my backup lights do not work. there was a blown 40 amp fuse in the engine bay,which has been replaced.no lamp out messages,bulbs look ok thru taillight lens, what could it be? the lights on the trailer did not function correctly from the start,but i never had a trailer hooked up before.
Old Apr 27, 2006 | 02:10 AM
Jim Dynomite's Avatar
It might be the backup light sensor on the tranny. There is a sensor with 2 wires going to it on the side of the tranny.
Thats the way it is on the 6spd anyway, hopefully I'm not misinforming you.
..............Jim
Old Apr 27, 2006 | 10:47 PM
dodgezilla04's Avatar
just had mine fixed today. lights worked intermittenly on my 6 speed. the $.02, chinese piece of junk only lasted 20 months. and it was $36.00 on the invoice, good thing it was warranteed.
Old Apr 28, 2006 | 07:37 PM
thunderdawg's Avatar
..............Jim
Same on the 5 speed. I just replaced my switch two weeks ago.
Dale
Old Apr 28, 2006 | 10:05 PM
handymantim's Avatar
The lamp out indicator doesn't look at the reverse lights. It looks at:
1. Headlights
2. Stoplights (except high mounted stop light)
3. Turn signals
Fuse #38 on a 2004 is for the reverse lights. If the fuse is OK then check the tranny switch.
Old Apr 29, 2006 | 08:04 AM
CRXsi's Avatar
Basically what everyone else has said...if it is a manual, switches are common, if it is a manual then first I'm not even positive our trailer wiring has reverse to it? It may but it's just that most trailers don't have reverse lights. Anyways first step is to confirm that the fuse is OK, next is to crwl under truck and disconnect reverse switch connector, now jumper the 2 terminals with a wire, paper clip, cotter pin, etc. Crawl back out and turn the key to the on position...is there reverse lights now? If yes then reconnect reverse connector and see if you still do...if not then you have confirmed that switch is bad. If lights didn't come on during test then confirm you have power at the switch (test light, DVOM, etc) if so then problem is wiring related and you will have to work with an electrical diagram to work your way back to the lights.
Hope it helps,
robert78.5
Jan 20, 2008 10:18 PM
greasefire
Oct 22, 2006 10:39 AM
dieselcrazy
Jan 25, 2004 08:08 PM
fanofthewolf
Nov 13, 2003 10:29 AM
NWDave
14
Nov 16, 2002 01:22 PM
