Back up lights
i had them on my 02 taco. they were all right. all they are, is a couple of cheap lights in a plastic housing. i did have to put a bead of silicone around each light to keep the moisture out. after a year i took it off and installed a nice set of kc back up lights. they were much better.
i bought the white knights from genos too. they dont quite fit like they do in their catalog. I have the factory hitch like their ad says you need, my lights wont fit under the bumper like the photo. my hitch has an extra brace on the top of the tube preventing the housing from sliding under the bumper. my buddies truck doesnt have this brace, and would work great on his. they are great for backing though. When they break, I will probably toss them in favor of some KC's too.
They fit perfect on my class 4 hitch assy. I saw dodgezilla04 setup, the bracket between his bumper and hitch does make it more difficult to install. I wired and completed the entire install start to finish in less than 20 minutes. But, you may have to add d-rings to the chain holes because the bottom of the unit covers nearly the entire area where the chains attach. (It can be easily fixed with a drimmel tool if needed.) For the price, it does what it is advertised for.
I bought the Genos lights but after I saw how it looked on my truck
I threw away the plastic housing and flush mounted the lights in the bumper next to the licence plate and moved the trailer plug next to the hitch. Mounted the three way switch between the tailgate and the bumper which makes it very hard to see but easily accessable.
From: North of the Frost Line....near Priddis Alberta
You can go to Wal-Mart and pick up a pair of inexpensive H3 halogen 'tractor lights' (either round or square). Make up a bracket that bolts thru the rear bumper bolt bracket and run a wire to the cab/your own switch/battery. I've tried a few backup lights and these spreader lights are good value.
You mean like these??? $11 @ wal-mart....about $30 total....They're 55 watts each, and Im thinkin of going brighter since I had my windows tinted
03CTDCO
Mar 6, 2010 10:48 PM
getrdun
Nov 26, 2008 11:46 AM
proudpapa97
May 4, 2008 06:50 PM
JoshPeters
Apr 3, 2005 08:13 AM
CHarlan
Aug 6, 2003 08:40 PM
