ATTN: all audiophiles!!!
Do you have any demonsions so that I could easily rebuild the box? I can do my own work and make something similar, but demonsions would save me some time.
I once built a box for two 12" Kick subs for a friends Volkswagon pickup back in high school. That box had more angles and notches to fit around things like the hump in the middle, seat belt returns, etc. It fit like a glove, literally. Someone broke into his truck and tried to steal his system, but couldn't get it out. LOL.
ben
ben
http://www.rockfordfosgate.com/rftech/box_wizard.asp
D1=8.5"
D2=2.5"
H1=18"
H2=5"
W = 21.125 (21 1/8")
Using 5/8" wood. Its impossible to get the volume needed using 3/4" mdf for the sub. If you use a 10" sub, you might get away with 3/4"mdf. Dont go any wider on the width...by the time you carpet it, its 21.5". I have to push the box just a hair to open the large side of the storage. I will measure later, but you might be able to push D1 out to 9"
click this link:
D1=8.5"
D2=2.5"
H1=18"
H2=5"
D1=8.5"
D2=2.5"
H1=18"
H2=5"
built mine with 5/8"... The recommended space was 1.0cu ft for the sub. The box was 1.01cu ft minus .07 for the sub = .94cu ft. I thought it was close enough. 1/2" would have been a little easier to get the 1.0cu ft
Your not gonna get a whole lot of flexing from 1/2" MDF with only 300 RMS, of which prob. only half is goin to be goin at any one time. You will only see peaks of 300 RMS never all the time.
Thanks, that was my first attempt at box building. It was designed with CAD (solidworks) to have an exact internal volume of 1.25 ft^3, taking into consideration all variables, (woofer displacement etc). Im sure that its not 100 percent perfect due to contruction tolerances but its pretty close to what JL specifies. That combined with the proper tuning of the JL 500/2v2 makes for a really clean sounding system.
Not a 3rd gen owner, but not getting much activity over there, so I thought I would post my stealth / budget / maintain full storage and space install I just finished. I know there are better components, but I was on a budget and had bought most of the things a few years back - just had not installed them. For example - I got the sub used for $25 and the rear Focals (new) for $60 from a install guy that was closing down and needed emergency $.
https://www.dieseltruckresource.com/...r-t246778.html
Where did you get the bolts for the box & how did you measure to get an exact fit for lining up w/the bracket in the truck? I can easily make the center console box but haven't figured out where to get the bolts. Also, if I mess up on the measurements for the bolts it will be alot of work to redo them. Thanks for your input regardless of what year your truck is. It's still a CTD!!!!
Just measure off the factory piece and line up the bolts. The holes are oval on the seat brackets, which makes it nice to adjust before tightening. Sit the top part ontop of the box and then measure for the flip up part and figure out where you want it. I had to move the flip up part back further than the factory console so my cup holder would fit and give me room for the shifter.
http://www.threeballclimbing.com/install4prongtnuts.htm
RottnRam
Jan 19, 2011 08:22 PM
97CTD
Feb 24, 2003 05:00 PM
