the annoying drip
Old Dec 3, 2007 | 08:40 PM
treadway47025's Avatar
the annoying drip
I have a 2005 dodge ram 2500 qc 4x4 speed cummins turbo diesel that I bought new and had the dealer install cab lights... Well everyone and a while on the drives side the top screw cover in the apillar grab handle will leak a little water when it rains... the dealer has looked at it and said the lights are fine and they did a tsb about where stripping... anyone else have this problem??
Old Dec 3, 2007 | 08:44 PM
tennman's Avatar
If you will peel back the top rubber door strip you will see several screws along the top used to secure the strip.
Coat each one with some clear RTV sealer and it will not leak again.
Old Dec 4, 2007 | 01:17 AM
Vinceg99's Avatar
Man I WISH mine came out of my grab handle! Mine has a leak through the little clip that holds the viser in place and that drips like right on my leg! I am alomost positive mines from my lights though.
Old Dec 4, 2007 | 09:05 AM
Rottweiler's Avatar
I bought my truck new and it had the same leak from the visor clip, the dealer could not find it. So I took out the screws for the cab lights and put just a bit of silicon on them no more leak.
Old Dec 4, 2007 | 10:58 AM
cgmorgan06's Avatar
Ive got a similar leak out of the visor clip, just started showing up when I put my recons on
Old Dec 4, 2007 | 01:31 PM
tennman's Avatar
This fix is for a leak at the grab handle. This area leaking is almost always from the door strip screws.
I have not had any leaks higher than that with my factory cab lights.
Old Dec 4, 2007 | 06:46 PM
CDoskocil9's Avatar
If its dripping from leaking RECONS they warranty them might wana check into that
Old Dec 5, 2007 | 08:38 AM
Hunter11's Avatar
I had this same problem with my stock cab lights. I had a small drip at the passenger visor clip when it rained. One of my lights had a hair line crack in it that was causing the leak. I bought another set of lights out of the classifieds here and replaced the bad one. No leaks since then.
Old Dec 6, 2007 | 12:00 PM
my lights were added by my dealer after I bought my truck new... I will check the door strip screws.. thanks for the advice.... would hate to drop the headliner to fix it..
BearKiller
Jul 11, 2022 02:43 PM
dslpwr81
28
Jan 26, 2009 09:08 PM
b4wheeler
Apr 18, 2007 03:54 PM
BearKiller
Feb 15, 2007 10:39 PM
thatguy
Apr 29, 2003 11:24 AM
