Amsoil Prices
Old Mar 13, 2004 | 05:19 PM
brillmtb's Avatar
Amsoil Prices
Local price for Amsoil 2000 75-90 fluid $9.29. Since I will need 7 qts I was wondering is this is a good price?
Would you put the 75-90 or 75-140 in the rear if you like me tow mostly during the spring-early Fall camping and given my trailer is only 24 ft (although it is a fiberglass sided Artic Fox so not the lightest).
Thanks in advance
Old Mar 13, 2004 | 05:24 PM
brillmtb's Avatar
I guess I should also ask for a quick yes or no on using amsoil vs going with DC fluid to avoid potential warrenty issues.
Old Mar 13, 2004 | 06:09 PM
Shovelhead's Avatar
Administrator / Scooter Bum
You could buy it straight from AMSOIL
www.amsoil.com
That's what's in my diff.
Old Mar 13, 2004 | 06:38 PM
papaduck's Avatar
The manual gives the type of oil to use, GL-5 75w-90 synthetic. If this is the oil used reguardless of brand the warranty should not be voided.
I was checking with the local Dodge dealer to get the specs on changing the oil in my 6 speed tranny and transfer case. The transfer case requires ATF+4 (Sold only by DM) and the 6 speed tranny requires a special oil mentioned only by a DM part number. On cross referance with a Shell guide it mentions this part number. The oil at 10.+ a guart is rather pricey. Need 9 pints.
Maybe someone knows of an oil for this tranny that will not void the warranty.
Old Mar 13, 2004 | 07:05 PM
dodgedude361's Avatar
i put the amsoil 2000 in my diffs, 75-90. yes its a little PRICEY, took 7 quarts. i paid about 9 bucks a quart. wierd looking stuff......looks like Nyquill smells good too
And before you ask, yes you REuse the gaskets.
Old Mar 13, 2004 | 07:39 PM
BDude555's Avatar
I've only got 5000 miles on the clock, planning on the change at 7,500 like the good book say's, I admit I really dont work my truck anything near like it was built for, so is it a mistake for me to go to the synthetic Amsoil this early? My intentions are to change the tranny fluid at this time to. dealer changed the rear end fluid out for me at 4,500 when I found a ton of metal goo stuck to the magnetic plug. stuff in there now is as clear as water! I watched him fill it with the correct stuff, its the clearest lube I've ever seen though.
Old Mar 13, 2004 | 10:30 PM
spud's Avatar
pennzoil synchromesh fluid meets chrysler specks ms9224 requiring part #4874464 it says so on the bottle. Its less than 5 dollars a quart.
Old Mar 14, 2004 | 08:28 AM
papaduck's Avatar
Thanks spud. Where did you purchase it?
Old Mar 14, 2004 | 08:56 AM
jthorpe's Avatar
DTR Founder
If you're going to take the risk, I would at least wait until 15-20k before changing over. 7500 is too early IMO.
Old Mar 14, 2004 | 10:44 AM
spud's Avatar
pappa duck
Auto zone in ogden ut. You can also uuse thr gm syncromesh fluid gm part #12345349 its all the same fluid
Old Mar 16, 2004 | 10:10 PM
papaduck's Avatar
Picked up some Penzoil at Auto Zone in Springfield, MO. Had to go to two stores, each store only had 4 quarts. Mopar part number is on the container and cost was 4.95 per qt.
Thanks again spud.
Old Mar 17, 2004 | 05:55 AM
JKE's Avatar
JKE
I am learning that you must stock pile the synchromesh! 2 quarts here 1 quart there. I still don't have enough on 2 separate trips a month apart...and getting them to call you when it gets there is impossible ...mf'rs - JKE
Old Mar 17, 2004 | 07:45 AM
SuperGewl's Avatar
You can probably pick up AMSOIL at your local auto store or GI JOES. If not you can get it by ordering over the internet form AMSOIL.com & they have plenty of it.
Spooler
28
Dec 26, 2009 10:16 AM
chipmonk
49
Jun 7, 2008 10:10 AM
czkid
Oct 18, 2007 07:38 PM
Fishcop
Nov 25, 2002 09:10 PM
