disabling door chime
Old 04-18-2005, 03:19 PM
hovisimo's Avatar
how would i go about permanently disabling the door chime? i'd like to be able to listen to the radio with the doors open and the key in ACC. more specifically, where is the chime located and what wire do i cut? thanks
Old 04-18-2005, 03:25 PM
mestdagh's Avatar
The procedure is in your manual.... a combination of key turns and seat belt maneuvering. You have to be fast and it'll take more than one attempt unless you memorize the process
Old 04-18-2005, 04:13 PM
hovisimo's Avatar
i knew it
there's so many of them i can't keep track of them all. i'll report back...
Old 04-18-2005, 04:42 PM
nickleinonen's Avatar
grab a bic pen [or stick of some sort], with the door open, use the pen to trip the door latch so the latch is in the locked position... the dinger will stop... just make sure to open the latch before trying to shut the door...
Old 04-18-2005, 09:09 PM
Fronty Owner's Avatar
geez, reminds me of an old truck I had, when I was running rough, you hit the dash twice, the steerign wheel once, stomp the floor followed by another crack at the dash, two quick pumps of the gas and a few choice words not fit for young viewers and it would run fine...
edit, btw, pull the switch from the body, disconnect the ground wire from it and you will not have that problem. but you interior light wont come on automatically either.
Old 04-18-2005, 11:11 PM
mestdagh's Avatar
If you think the dodge door chime disable is tough, you should see the procedure for my Ford Focus. It's 2 pages long!
Old 04-19-2005, 01:16 AM
powerstrokin03's Avatar
so does anyone know what page it is in the manual? i cant find it thanks
Old 04-19-2005, 01:46 PM
Lsufan78's Avatar
not sure what page, but it's under the seatbelt part of the manual
later, dustin
Old 04-19-2005, 08:23 PM
hovisimo's Avatar
let me know if you find it, i just read the entire section and did not see anything about disabling the door chime, only the seatbelt chime.
Old 04-20-2005, 08:05 AM
Lsufan78's Avatar
give me a second...i had to PROVE to somebody that it was in there. so i scanned and saved it, let me dig it up!!
later, dustin
Old 04-20-2005, 08:10 AM
Lsufan78's Avatar
later, dustin
Old 04-20-2005, 09:33 AM
Breakin Loose's Avatar
That's for the seatbelt chime, but that doesn't deactivate the door chime.
Old 04-20-2005, 10:00 AM
Lsufan78's Avatar
ahh...what a dummy, guess it would help if i read the threads better!!
later, dustin
Old 04-20-2005, 03:42 PM
dgm
dgm's Avatar
....to disable the seatbelt chime, you can also plug the middle seatbelt end into the driver's receptacle. I've done that because I didn't have enough patience to get the procedure in the manual to work. One of these days I'll try again though.
If anyone knows how to disable that door chime though, that would be great!
-daniel
Old 04-20-2005, 04:23 PM
torqueman's Avatar
door chime
Hey guys if the 3rd's are anything like the 2nd's just push in the door trigger while on acc and door open and chime will stop.
Quick Reply: disabling door chime
