Air Bag Question
Air Bag Question
Simple question about air bags for those of you that have experience. I am looking at putting a set on the rear of my truck for when towing. When looking at them, it looks like the minimum pressure that you can run in the bags is 5psi. I know this isn't much, but was wondering if this was enough to make a difference in the ride height of the back of the truck when unload. So when unloaded and bags deflated to 5psi or pressure how much force to the bags produce at this pressure and will this be enough to raise the rear of the truck some small amount, or will it sit back to normal height when at 5psi.
At 5 psi, you really shouldn't notice any difference in ride when unloaded. That little bit of air is needed to help the bag maintain shape, but it's not enough to stiffen things up. If your truck is stock, then the rear is so stiffly sprung that it would take a lot more air in the bag to make a noticeable difference anyway.
I used to tow HEAVY, for quite a while....to the point where the rear leaves began to sag. Installed bags to bring it back up to what I say is a factory stance. I keep about 35psi in mine all the time. Yes, it can be very bouncy, but I have found that even a little extra weight of sorts in the bed really smooths things out. If you are towing a load the air bags make a world of difference in ride quality IMHO.
Towing is like night and day with the air bags, it smooths out the ride that unless you come to a really good incline or a stop it doesn't feel like you're pulling a decent load and you don't have that "fatigue" from fighting it down the road.
-Kris
I just put some on my truck
holy crap they'll bounce the hell outta you at 15 psi empty on a rough washboard gravel road, thought I was gonna shake the truck apart. on a speedbump in some parking lot it'll send your rear end to the clouds like you had some mexican lowrider hydraulic system bouncing the rear skyward
I don't give a crap if I ruin the bags a few years earlier than they should be I'm going to run mine with only a couple psi empty - 15lbs is too much
BUT
loaded what a difference, I bought a camper and I don't have overloads. It's a pretty big camper for the truck - truth be known I'm gotta be a good ways over my GWVR, its a 10.5 footer built 1996 and it sure put a squat on the truck without bags
now I air them up to 80 lbs and the truck is flat, haven't drove it yet though, think I'll need anti sway bars on the rear axle it feels like I could almost push the truck over by rocking the camper
BUT
I got to drive the camper around towing a little trailer with a few ATV's on it and the sway is a little more than I like but very managable
I might toss on a rear axle antisway bar
been running bags for many O year now. I when empty run my bags free aired by that I mean I back stems out a little and drilled a tiny hole in valve cover cap. This way as the truck move and air is free to move in and out of bags and it don't affect ride at all.
