Advice On Rickson Wheels?
Yes, and I had to ask a couple of people before they found them in their system. They also sale a good choice of tires up to 245/19.5 but I would like to move up to a 265 and they only had one choice. I am going to see if Costco can special order me some.
Of you that own the vision's what would the weight difference be between them and stock mounted up. Is it very noticeable or is 20-30 #'s per tire/rim. I'm just worried about gvw since I only have the 2500 and tow gooseneck. thanks for the replies.
My tires are 95lbs each, wheels are about 40lb each...stock tires and wheels, I would guess would be about 60-70lbs lighter per corner. BUT, I do have 285's, which are 16 ply, and probably a bit heavier than most 19.5's!
Why would that matter on a 2500 towing a GN??
Chris
Chris
Thanks
signature600 I tow a 16k dump trailer and I'm a bit over on tongue wt as it is. Sp i am trying to kee the trucks weight down. But a set of 19.5's would be much nicer for towing all the time, a bit safer. I would love to get the gvw raised on my truck but not sure how. Thanks for the info on the rims & tires.
Gotcha...if you're towing, I'd just stick with a 225 or 245, anything bigger and they get pretty tall, but wouldn't be as bad with your 4.10's as my 3.55's
Chris
Chris
I have the new 6 speed and even with my ~ 34 inch tires (245/19.5/70 Michelin XDEs) I would like to drop the highway RPMs even more. As far as towing goes I have 6 gears to play with and can easily shift down for more power.
Either way, I would stay away from the 285's if you tow often. A 35.5" tall, 150lb tire/wheel combo is really gonna hurt your towing mileage and power...but if you want to run in 5th gear, I'd say you'll be fine!
Chris
Chris
BrianW250
06-12-2008 02:09 AM
