adding dash speakers
Old May 21, 2012 | 08:13 AM
SLSD400exGUY's Avatar
my truck came without dash speakers so i bought 3 and want to add them.
does anyone know how to wire them up to the radio. do i tap into the door speakers or what?
thanks for the help!
Old May 21, 2012 | 09:36 AM
1mathom1's Avatar
It is my understanding (could be wrong) that the trucks that have dash speakers have a different amp than those that do not. You may not have a choice but to tap into the door speaker leads for the left and right. The center channel is a different deal. Not sure what you would hook it to unless you change the amp
Again, I could be wrong but i believe the center channel speaker is much different than the 3.5" speakers on th sides of the dash. you may have to do quite a bit of whittling to get a regular speaker in the center channel.
Old May 21, 2012 | 05:41 PM
ColinP's Avatar
If you are not using an external amp, the easy way to do it is to run the dash and door speakers in series. Splice in behind the head unit and you will only need to run wire through the dash. The fronts will be at about 8 ohms so you will want to adjust the sound accordingly with the fader. I would not install a center 3rd speaker unless I had a head unit designed for it.
Old May 22, 2012 | 05:35 AM
sounds good. i only bought 2 but my buddy had 2 so i was gonna use one of his but it seems easier to just forget about the center one.
whats if i was going to add a 10" sub in the back where would i splice?
Old May 22, 2012 | 12:16 PM
ColinP's Avatar
Assuming you will add the sub with an external amp using the high level inputs, I would tap the rear channels at the head unit.
Old May 24, 2012 | 05:53 AM
awesome thanks guys!
tpollon2
Jan 8, 2011 08:47 AM
NoSparkplugs
17
May 17, 2009 10:36 PM
snowmanx
Sep 19, 2006 08:25 AM
sstengler
Nov 21, 2003 08:35 PM
