ABS nd Brake Light on, No Speedo
Old Apr 11, 2008 | 09:59 PM
TweetyBird's Avatar
I was driving hoime tonight, and all of the sudden the brake light and abs light cam on, and i lost the speedo, it shows 0 mph. Everything else is great. Any ideas? THX!
Old Apr 11, 2008 | 10:00 PM
2006Mega's Avatar
rear wheel speed sensor located in the rear diff. check to see if their is a loose or cut wire.
Old Apr 11, 2008 | 10:34 PM
TweetyBird's Avatar
Wow, I put on some MaxLoader overload springs today, hmmmmmmm. where exactly is it?
Old Apr 12, 2008 | 03:03 AM
LFD2037's Avatar
Check ABS fuse, also.
Old Apr 12, 2008 | 10:18 AM
2006Mega's Avatar
on top of your rear diff there is a sensor, i checked on my friends 03 and the sensor was held in with a steel bracket so it might be different than yours but probably not. one wire was cut on his, so no abs, but i am not sure if the speedo was working.
the wires then run up to the drivers side frame rail.
Old Apr 12, 2008 | 02:00 PM
NDanecker's Avatar
The speedometer only needs 1 single from either the front left, right or rear ABS sensor to get the speed. If everything went out at once this means you aren't getting a signal from any of the 3 sensors...which is odd.
Maybe a fuse????
Check the codes. That will tell you which if not all of the sensor circuits are at fault.
Old Apr 14, 2008 | 02:40 PM
rahtok's Avatar
This just happened to me last week. Took it in for service and the ABS module itself had died. Glad warranty was still good.
BTW, the error code that it was throwing was 121. The Smarty just read it as "unknown code".
Old Apr 14, 2008 | 02:50 PM
TweetyBird's Avatar
Thanks for all the replies. I played around with the wires on the sensor, and everything started working, must have been a loose connection.
Joey-D
Dec 12, 2011 12:52 PM
mr T
Feb 24, 2007 06:42 AM
Rocksville
Aug 21, 2005 09:58 AM
z1bigtom
Jul 30, 2005 06:04 AM
