4wd low light flashes couple times and goes out
Old Aug 3, 2010 | 06:49 AM
skindaddy's Avatar
driving down the road last night and 4wd low kept coming on flashing on off a few times then out for 10-30 seconds then repeat.
not today though
any thoughts?
Old Aug 3, 2010 | 05:45 PM
Prodart440's Avatar
Maybe a bad ground??
Old Aug 3, 2010 | 08:05 PM
2171CTD's Avatar
Check the connector going into the transfer case. Make sure its contacts are clean and the connector is tight.
Old Aug 4, 2010 | 06:45 AM
skindaddy's Avatar
did not see it happen yesterday afternoon, but did it again last night , AND turn into gas station and felt like in 4wd a few times with no light on . Oh great!
anyone have this happen?
sorry should have put in drivetrain forum
Old Aug 4, 2010 | 01:51 PM
2171CTD's Avatar
Is your Tcase electronic shift or manual shift?
This may fix it with either style shift. Properly shift into 4low drive a short distance then properly shift out of 4low. Allow Tcase to fully shift out of 4low then shift out of 4wd into 2wd and see if that fixes it.
My 06 with electronic shift got stuck in 4low once. It was the connector on top/front of the Tcase. It had wiggled loose a little bit and was not make a good connection. I disconnected, sprayed with contact cleaner and reconnected, no more problems.
Old Aug 5, 2010 | 01:51 PM
TurboAddict's Avatar
I'm having the same issue with my 2010 Laramie with 166 miles. 4wd lo lamp flashes and I hear some noise coming from the front as though it is trying to engange. Took it to the dealer and they cleaned a connector and sent me on my way. 2 minutes later the lamp started flashing again then felt like four wheel drive was trying to engage. Took back to the dealer the next day. have yet to hear back from them. I have the electronic 4-position transfer case.
p0wd3rp1l0t
Jun 27, 2012 10:29 PM
thenrie
Sep 25, 2011 04:47 PM
TurboAddict
Aug 30, 2010 11:42 AM
wcbcruzer
Sep 5, 2008 08:36 AM
Earthmover627
Jan 17, 2007 04:35 AM
