2005 Owners - How are things holding up?
ok I'm not in the right MY... but still the same general vintage.
CP3 pump leak at 20-something - warranty replace.
Front diff pinion seal at 34K - warrany replace.
just about to pass 36K now so the B-B goes... but I've got the 7/70/100 left.
In both cases no symptoms... just noticed the stains when changing the oil.
A good reason to crawl under the truck and look around. There's plenty of room under there parked on the ground - don't even need ramps or a lift.
Bought mine in March 05, it was fine for awhile but then it started,
1 Clutch fluid leak from reservoir under hood
2 Water leak from bottom of door when raining, road mist
3 Water leak from top of door
4 Water leak from cab lights
5 Door seals ripped, DC only replaced drivers side
6 Crank position sensor
7 Bad miss cause by " severe malfunction in injector system"
8 Rebuilt transmission
9 Still missing
10 ECM replaced
truck was good till about 25-30,000 miles, it now has 40,000 and still sitting at the shop, it went in on Dec 16 and Im supposed to pick it up tommorrow, 1-20
I use this truck for my business and have lost between $300-$900 every weekday since, this dodge has broken me and there will not be another that I depend on for my livelyhood
9 Still missing
10 ECM replaced
bought mine in august about 5,000 miles now. No problems at all so far. My only complaint was finding out I had to buy the heater plug. I get about 15-16 on winter blend was getting 17-19 with summer blend
Got mine in Jan 05 13000 on it, mostly road trips and playin in the hills. Only problems I have are sometimes it is real hard to start have to push pedal to floor before it fires and the driver side door leaks air about 90, must be that door seal thing.
kev94mx
19
Jun 15, 2007 07:33 PM
vbert
Jan 25, 2005 06:03 PM
Jim Weed
Aug 24, 2004 08:52 AM
