2 guage mount?
Old Mar 24, 2008 | 03:43 PM
papaduck's Avatar
2 guage mount?
I have 2 guages that are mounted on the steering column and I do not care for them there. I do not want to do away with the handle on the column by the windshield nor do I want to put them in the cubby hole in the dash. I must not put them on the top of the dash as my wife is short and she would have trouble seeing over them.
I am not sure that I want to put them over the mirror but maybe that is the best solution.
I would like them under the handle on the verticle column but haven't found a mount for that.
Has anyone managed a better solution mounting 2 guages?
Old Mar 24, 2008 | 11:17 PM
Equalizer 2's Avatar
Looking at your signature it looks like your guages are EGT and Boost. I solved that problem with a EGT/Boost Combo guage from Westach and an SRT10 pillar. The SRT10 pillar has a single guage mount built in below the handle and then you replace the pillar in the truck. Others on here have done the same and I am very happy with it. I think I bought both the Westach and Pillar from genosgarage.com.
http://www.genosgarage.com/prodinfo....-DG-ZL39TL2-AA
If I was to do it over again I would probably go with the Quadzilla Commander just for the guages with the pillar mount. It is a bit pricey but you can monitor a lot of different things just by selecting them. I think you can get the stuff you need for the Quad system from the DTR Store but give Lary a call to make sure.
Old Mar 25, 2008 | 07:44 AM
papaduck's Avatar
Thanx Equalizer for your reply. I actually have 3 gauges, the boost/EGT combo and lift pump pressure in the other. They are Westach from Geno's.
J10495T
Sep 21, 2011 04:07 PM
chw
Dec 25, 2006 04:30 PM
ckennedy
Nov 15, 2004 05:35 PM
12valve@heart
Aug 11, 2004 03:43 PM
Homestead
Oct 7, 2002 06:45 PM
