1/2 quart low
1/2 quart low
checked the oil on my o4.5 1/2 quart low .truck ben seting on level ground four days 13800 miles since i have switched over to amsoil .i was runing rotel changing oil and filter 3 to5 thousand miles never semed to use a drop. is this normal or not. easy runing most of time.truck now has98500 miles.did anlise on amsoil at12000 mil every thin ok. posible seal leaking in turbo? check oil level every second to third fill up. just semes like it used1/2quart last1500 miles iny info would help.sotex
Doesn't take much off of level to make that much difference. Mine will change with the slight slope of my garage floor. Make sure you check in exactly the same position before you get too concerned or spend any money.
Mine has ALWAYS used a half quart between changes. Used Amsoil and Dino and never made a difference. Mine too is totally sensitive to being dead level. I try and ck it when the oil is still HOT. In the cold the oil shrinks some when it cools. Shut her off, wait half hour, and then ck it.
one of the reasons i switched to amsoil was the fact that i should be able to go 3 times the distance betwen oil changes. after oil analyze said ok to keep going.i figured i would put 15000 miles on oil take a sample for analysing and change oil and filter .sotex
snowmanx
Jul 7, 2007 05:48 PM
Common
Oct 5, 2006 11:23 PM
