06 3500 Incoming air
Ok - Strange situation.. I've always thought there was a draft inside my cab even with the vent's of. The other day - heading our fishing with my bro, he says his knees are cold.. (he's 6ft 6) - No vents on no nothing - so I turn on the heat.. Seems like there is a draft coming in from the outside of the vehicle right where the glove box is.. Anyone experienced this..? I haven't torn in to the dash yet..
I would bet the recirculation door has broken.
Remove the glove box by pulling the back corners in as you tip it out.
You will then be looking at the in-cab intake grille. If it is set on fresh air, you should see the tanish plastic door blocking the grille. In the recirculate mode, the door flips up to block the passage to the intake grille ahead of the windshield.
My guess is that it is flopping around broken, letting in outside air all the time, regardless of what the mode doors are set to.
BigBlue
Mar 13, 2007 06:29 AM
jmccart
Dec 12, 2006 02:07 PM
ptgarcia
Sep 12, 2006 06:04 PM
