05 rear power window problem
Old Sep 3, 2007 | 06:40 PM
57ringo's Avatar
I have an 05 Quad cab CTD. The rt rear power window will not move with the drivers switch but will go down with its own switch but not up. Anone run into this? I can jump the wires across and act like I'm rolling it down to make it roll up so that's telling me the motor is working.
Old Sep 3, 2007 | 06:44 PM
3500_CTD's Avatar
your switch is bad then you gotta figure out wether its the front or the rear one now..
Old Sep 3, 2007 | 06:52 PM
57ringo's Avatar
I swapped the back switches and that didn't make a difference.
Old Sep 3, 2007 | 06:55 PM
3500_CTD's Avatar
then its the front one driver one if you can jump it then the motor works fine and the switches have to be good or neither of them will work correctlyby the sound of it id say it is the driver one.
go get a switch when you have time if it doesnt work then return it thats all but it deffinetly sounds like the driver one to me.
Old Sep 3, 2007 | 06:57 PM
57ringo's Avatar
I used a tester like this one http://cgi.ebay.com/ebaymotors/ws/eB...147968938&rd=1
and it showed the drivers switch to work too but somewhere between the drivers door wiring connector and the connector at the rt rear door, it lost juice. Is there another wiring connector between the two somewhere?
Old Sep 3, 2007 | 07:01 PM
3500_CTD's Avatar
just the whole wire harness connectors in the pillers for each door, that sound weird then what are you testing on the front one
Old Sep 3, 2007 | 07:07 PM
57ringo's Avatar
I checked the polarity at the drivers door switch and at the post and it seemed to be ok. It does not check ok at the rear door post connector when operating the drivers switch. I guess it would eliminate things if I tried another drivers switch to make sure though.
Old Sep 3, 2007 | 07:09 PM
3500_CTD's Avatar
yea the way it sound i still think it is the driver switch do you have any friend with the same swich in there truck that they will let you test with
Old Sep 3, 2007 | 07:12 PM
57ringo's Avatar
Got a buddy down the road a couple miles I'm trying to call. I'll let you know later...thanks.
Pat
Old Sep 3, 2007 | 07:13 PM
3500_CTD's Avatar
yea hopefully you can figure it out good luck!!
Old Sep 4, 2007 | 01:09 PM
57ringo's Avatar
I put another drivers door switch on and it still does not work. It looks like I have a broken wire somewhere between the drivers post connector and the rear passenger window.
Txwelder
Jun 16, 2013 02:10 PM
Rednecktastic
Aug 29, 2010 11:26 PM
rmalone
Aug 19, 2008 11:22 AM
raven392003
Oct 29, 2007 11:39 AM
tslewisz
14
Feb 2, 2006 01:09 PM
