XRT PRO or Smarty Jr
I have all my deletes ordered, pipes egr kit and will receive soon. My question is about The XRT PRO and Smarty Jr. I want to run stock with deletes and both tuners can do this tune, however I was told that the Smarty Jr Stock with deletes tune must be down loaded from a PC after you receive the unit Have any of you found this to be the case. Also I bought a K&N drop in filter to use in the stock air box. However when I install run for a few miles I get a dirty filter code. I clear the code and install the stock filter and its fine. Any of you ever had this prob. The K&N is new.
Jim (RED RAM) Bolding 2007 Red Ram 6.7 and loving it
Santa Clara Utah
Santa Clara Utah
Location: misplaced Idahoan stuck in Albuquerque, Roughneckin on RIG 270
as for the air filter code, its normal. dodge did a flash on it for this and if you install a high flow air filter you will get a code. no way around it.
as for the smarty, if you ordered it with ME installed you won't have to touch it.
Number4b
09-12-2012 01:49 PM
walks
04-30-2012 01:26 PM
TurboPirate24v
02-16-2012 02:18 AM
