Turbo??
Turbo??
My buddy is gettin a 08 6.7 and he's goin to put 100 horse nozzles and a DD valair smarty ssr what size turbo should he get a 64? 66? Thanks
Location: misplaced Idahoan stuck in Albuquerque, Roughneckin on RIG 270
stock 6.7 injectors spool a 64 pretty nice. better do more than just turbo and injectors. studs and fuel system and programming, also going to lose the exh brake
with the manual you can spool the 66 fine even on the stock fuel system. He is going to need studs and depending on how he drives he may need more headwork. If he drives conservatively then he'll probably be ok if he drives like me (foot on the highway) then he will probably need more than studs. As CBRAHS stated with that large a set of injectors hes probably going to need more fuel from the lift pump and maybe the cp3.
heres an idea what the spool up will be like on a stock injector/cp3 truck
j
01-09-2004 08:19 AM
Haulin_in_Dixie
07-21-2003 11:14 AM
redram
12-10-2002 09:54 AM
