Smarty Jr ME questions
Ok, so I've done the deletes and have the Smarty Jr ME installed, stock settings. I'm curious to try the 40 and 70 hp settings, but when I go through the software, I only see X, STOCK, TOWING, 3 PERFORMANCE. I'm a computer savy guy, but can someone explain this to me?
What is X?
Obviously stock is stock, but I don't see a 70 hp setting. Is 3 Performance the 100 hp setting? I guess I could load them all and try, but I want to be sure of what I've programmed into the ecm before its done. Any other Smarty Jr owners that can assist me?
What is X?
X - setting that returns ECM to stock, unlocks smarty from your vin.
Stock - no horsepower or timing or torque management change, but dpf delete will still be fine, and egr will be commanded to 0%
Economy - 40hp, timing change, torque management change etc.
(should be listed if you have 21ME)
Towing - 70hp, timing change, torque management change, etc.
Performance - 100hp, timing, torque change, etc.
Smarty does not seem to have the best instructions or literature, but the **** thing works, so it is hard to complain.
Scott.
Scott.
Thanks for the info. Loaded up the economy and towing tune. I can't really imagine towing at the 70 hp setting (tow tune) and not wrecking something. Sure smokes the tires though. Have the economy tune loaded and will try that. Actually I like the stock setting as well, that way I'll know I won't/should'nt wreck anything.
The smarty is an amazing product!!!
"California Style"
It does seem a bit odd that the towing is the next to highest setting...
stock03
34
04-21-2011 07:40 AM
Sam Turner2
27
12-24-2008 09:52 PM
D.Wiggs
31
08-30-2007 02:48 PM
CTD_Neil
02-23-2006 09:27 PM
