3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
S67
Old Apr 16, 2009 | 04:57 PM
Chubby's Avatar
S67
Got it today. Have it on the 90 hp setting ....... Going to check milage this weekend
Old Apr 16, 2009 | 08:38 PM
z28fan's Avatar
Hey chubby whats the smoke output?
Old Apr 24, 2009 | 07:48 AM
Chubby's Avatar
Well first tanlk of fuel milage went from 13.8 to 16.9... I had it in the 90 with timing. Pulled my 40 ft toy hauler like a dream
Old Apr 24, 2009 | 09:00 AM
X-rated's Avatar
EGR unplugged? DPF delete? What else have you done from stock??
Old Apr 24, 2009 | 03:36 PM
mega-engr's Avatar
"California Style"
Thanks for the feedback. I got mine too recently, but haven't tried it yet. Please keep the information coming. Wondering which setting to try first.
Old Apr 25, 2009 | 02:31 PM
blwnsmke's Avatar
Buddy of mine just put this on his. Said when he uses settings with timing his truck is clattering really bad when he gets on it? Anyone have this issue?
Old Apr 26, 2009 | 10:00 AM
Chubby's Avatar
Its called timing..... Mine does it no big deal. Timing will get you the best milage too. I have everything deleted
Old Apr 26, 2009 | 10:48 PM
blwnsmke's Avatar
I know its timing.. I have not personally heard it on his truck yet so I don't know how bad of rattling it really is. And being a new motor design and all I figured Id ask really quick.
Old Apr 27, 2009 | 07:55 AM
Chubby's Avatar
I think with the timing there is mailage gains but also It dosent smoke as much
Old May 5, 2009 | 12:37 AM
rbmedic75's Avatar
true timing will get ya better mileage but to much can be a bad thing your motor will actually be drawing fuel in to early (before the piston is top dead center) which will try and push the piston back down and break stuff up pretty bad. He may need to play with the CATCHER software some and turn the timing back it has option 1-4
Old May 5, 2009 | 05:59 AM
mm73's Avatar
That is the same setting I run on mine, sw5 and it is my favorite. not too little and not too much just enough to have fun with and not tear everything up. I leave all the other parameters default.
Old May 5, 2009 | 10:39 AM
Lil Dog's Avatar
I hear alot of "clatter" reports for the Smarty.. I guess these persons haven't had a 12V or a VP44 24V engine? Advanced timing is the ticket for the 6.7 as the factory tune retards the timing hugely to lower the Peak Firing Pressures and keep the NOX down. The slight clatter I hear is really minor IMHO compared to my 12V and now sounds more like a diesel engine instead of a gasser with a few dirty injectors.
The advanced timing will cause higher peak pressures and if with high amounts of fuel, cause head gasket failures but not the damage reported here. Diesel fuel needs heat and pressure to fire, so ultimately if you inject too early, you really only get poor combustion and poor performance. Typical timing would be as early as 25° BTDC for high performance VP44 timing maps and as low as 6° for retardation for emissions control.
Old May 5, 2009 | 03:05 PM
BroncoHound's Avatar
Very well written. My '08, with SW3 and timing on level 3 still doesn't sound ANYTHING like my bone stock '01. The '01 has 360,000 miles and has made that timing "tick" for every one of them so I seriously doubt it is hurting anything.
Old May 15, 2009 | 04:59 PM
jthorpe's Avatar
DTR Founder
Chubby, got any numbers on the mileage gains yet? If any?
Old May 15, 2009 | 05:43 PM
Im not chubby (though i could probably stand to do a few more situps each day), but I have noticed a solid 1.0-1.2mpg gain over stock programming with the smarty on SW3, TQ-default, TM-3, RP-default. This is with a 60/40 mix highway/city. On my normal route with a 5" TBE (obviously DPF deleted) and EGR delete and stock programming, I would typically yield 17.0-17.3mpg each week. Since the Smarty, I haven't had a tank fall below 18.0mpg and my normal route (bobtail) is typically 18.1-18.5mpg. I haven't had an opportunity to test the pure highway efficiency yet, though after 3000 miles of the daily grind with the Smarty, I think it's safe to say my increase is legitimate. Keep in mind that I have NEVER seen any kind of fuel economy increase with any kind of programmer before the Smarty. I have run the Power Pup, the Juice w/Attitude, the PMT, and the Extreme PowerPuck at one time or another on this '08 and haven't seen a lick of fuel economy increase with any of them. I'm pretty impressed with the Smarty thus far, though I haven't been over SW3 and doubt I ever will. I am the anti-hotrodder, at least in my 8000lbs. pickup truck.
I've got a 3000 mile trailer-pulling trip to make next Wednesday. The trailer will only have a motorcycle on it for the way up to Ohio, but will have a '71 Impala (my brother's latest toy) for the trip back. I intend to post my fuel log of the trip upon my return. I will also have another trip to take immediately after, this one only 900 miles or so, with the trailer empty for half of it but with an old '79 Ford pickup of my fathers for the trip back. I intend to also post the results of this trip. Hopefully the Smarty impresses me as much with the trailer behind the truck as she does bobtail.
