3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
Need Help: Question about EGR blocker and SMARTY
Old Dec 10, 2009 | 05:57 PM
shlen's Avatar
I'm am looking at installing a AFE Intake, SMARTY Tuner and AFE exhaust. With what I have read, my question is:
"I was wondering if that AFE Kit came with a DIRTY EGR blocker kit or something like that to remove all the emmissions components
EGR/CAT/DPF. I believe with what I read that the smarty will remove the DPF, CAT, and EGR codes but you actually need a blocker kit to stop the flow to the EGR."
I recieved a reply:
"I have looked into the blocker kit and there is NO need for it with the set-up I sourced for you. Reason is the install procedure for the Smarty tuner is to unplug the throttle switch so the EGR never opens again. I am not the ultimate expert on this procedure - but my sources indicate to me that the EGR will be kept out of the system. The exhaust gases will not block up the system"
Can anybody clarify this answer or do I need a EGR blocker kit?
Sorry might have put this in the wrong section.
Old Dec 11, 2009 | 10:41 PM
jballou's Avatar
Can someone move this post to 6.7l performance? Will get more exposure there.
Old Dec 12, 2009 | 01:30 AM
shlen's Avatar
Sorry can not figure how to delete this post.
Old Dec 12, 2009 | 03:40 AM
Clane's Avatar
dont worry it's fine here too....as long as you dont change your avatar....
Old Jan 14, 2010 | 08:46 AM
Jim W's Avatar
I recieved a reply:
Yes, you will need to block off the EGR and remove the tube assembly in front. I purchased my blocker plates on line from one of the members either on this forum or from this forum:http://www.cumminsforum.com/forum/
I would do a search on these two forums and look for EGR blocking plates.
Then you will need to follow the instructions on the Smarty Web site that you down load and print.
This has worked for me and I am very happy with my set up.
Good Luck
Old Jan 15, 2010 | 12:03 AM
mega-engr's Avatar
"California Style"
Good Luck
You don't need to remove or block off anything if you don't want to. Just follow the instructions on the Smarty ME. You remove the plunger from the EGR motor is all. I put a freeze plug into the EGR tube for some safe measure and left everything in place and looks stock, but performs much better!
shlen
Dec 11, 2009 01:04 AM
MOJO1
Aug 4, 2009 06:28 PM
DodgeDemon
16
Apr 28, 2007 03:02 PM
Hoss
Dec 31, 2004 02:56 AM
