3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
EGT reading's
Old Sep 17, 2011 | 12:47 PM
orr's Avatar
orr
EGT reading's
So what are the temperatures you guy's are getting with the SM JR. I have SW3, Timing 4, Tourque Default, Airbox mod with a K'n'N filter and deletes, still have the Cat though. At 1700 RPM and 110 KMPH with no load the guage reads around 700 F. with about 8-900 LB in the box it reads closer to 850 F. I haven't towed my trailer since the guage was installed so I'm expecting the temp. to go up. I read somewhere that 1200 F. was damaging, is this right? Also at Idle the temp. after a drive of 850 F. goes to about 400 F. when the start up idle is 300 F. I'm curious what the stock temps. are as well. Cheers
Old Sep 20, 2011 | 10:14 PM
orr's Avatar
orr
let me rephrase the question. What are the stock average temps compared to the modified? Thanks.
Old Sep 21, 2011 | 07:42 AM
ATOYA4U's Avatar
You could answer your own question by just puting Jr back to stock!
Old Sep 21, 2011 | 08:30 AM
orr's Avatar
orr
Thanks for the help buddy!
Truck has deletes, as it says under my post. probably not going to read the same if software is the only thing returned to stock, but thanks anyway.
Old Sep 21, 2011 | 02:22 PM
SpeedyWS6's Avatar
Yours runs cooler than mine, but I can't answer your question.
Old Sep 21, 2011 | 02:52 PM
John_P's Avatar
orr:
Your EGT's seem to be in line with what I see on my 2006 Dodge CTD CR with a Smarty stacked with a TST.
A safe "guide" is not to let your EGT's exceed 1300 degrees if your probe is in the exhaust manifold and 1,000 degrees if the EGT probe is in the downpipe.
I would try hooking a trailer with a load and see what happens too. I am guessing the EGT's will go up higher then.
Hope this has helped you some Sir!
John_P
Old Sep 21, 2011 | 05:20 PM
orr's Avatar
orr
Thanks for the info guys, greatly appreciated!
Once I tow my trailer again I'll post my results. Cheers!
Old Sep 21, 2011 | 07:36 PM
mega-engr's Avatar
"California Style"
I hit 1250 sometimes when towing before I down shift or my trans does on a hill/grade. I try not to let it get over 1100 though before I down shift. Cruising, I am at about 850 to 950... No wonder I only get about 9 or 10 MPG towing... I don't get much of a chance to see what it is unloaded cause I hardly ever drive it unhooked. I'm going to make it a point to pay attention unhooked.
Old Sep 22, 2011 | 08:45 PM
rams2500's Avatar
Lets remember these trucks regen factory around 1400 degrees. Not a license to abuse but they are built for more heat than the 5.9 factory.
Old Sep 22, 2011 | 09:04 PM
SpeedyWS6's Avatar
That's why I don't even worry about how hot mine runs. My 5.9 burried a 1600 gauge more than I care to admit.
My 6.7 runs around 900 on flat ground at 70, but rarely ever gets over 1250 even when pulling hills with a load.
My convertor will shudder before it will lug hard enough to get the egts too high. So because of that I keep the rpm's up when towing resulting in lower egts.
Old Oct 6, 2011 | 12:30 PM
rampowers's Avatar
I just went from SCL to Wendover with no mods on my 2007.5 6.7 i saw 900 -1500 driving about 78 mph. i found it hit 1500 for about 2-3 sec. before returning back to about 1100.
mullishacrew
Mar 18, 2012 12:41 PM
jmccart
Mar 18, 2007 10:03 PM
WICTD
Dec 8, 2006 03:58 PM
0425004x4
May 9, 2006 10:57 AM
