3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
Automatic Transmission manual shift
Old May 7, 2013 | 12:00 AM
lostcause72's Avatar
I bought my truck about a year ago and it came with the mini maxx and deletes already done. Since owning it the manual shift +/- button has only worked for downshifting and not the upshift. I first assumed it had something to do with the mini maxx withought the overdrive program loaded. I bought the overdrive unlock code and loaded it (so far pleased with it) however the problem is still there, i cannot upshift. Has anyone else dealt with this or know of how to fix this?
Old May 7, 2013 | 01:11 PM
d6c's Avatar
d6c
Sounds like it is correct to me....You can force a downshift by toggling minus....and when you toggle up it just sets a new high limit...and like any automatic it will upshift when it senses conditions are correct.
Old May 7, 2013 | 07:46 PM
2006BLKMegacab's Avatar
does the gear selection indicator change when you push the up button? if so then it is working as it should, you cant force it to upshift with the button, only down
ebanezar
16
Mar 5, 2011 01:06 PM
RollsCoal
Jan 5, 2010 06:35 PM
SWATPARAMEDIC
Oct 19, 2009 03:25 PM
CReed
17
Feb 2, 2007 01:13 PM
johnr9q
0
Mar 20, 2006 10:19 AM
