6.7L mod that I bought
Hey guys I already have an aFe mega cannon kit on my 08. I bought a new mod and it should be shipping in the next week. Thought I would pass it on to the rest of you guys just in case you are interested. I bought through a group buy. If anyone is interested I can forward you the guys info that is setting up the group buy.
Well I finally recieved the part. Guess they were on backorder. I installed the part and I can really tell a difference in the bottom end. I cant tell anything at the top end. As for mpgs I only have 100 miles on it right now so I cant say that it increased just yet.
I found this on ebay if anyone is interested.....
http://cgi.ebay.com/ebaymotors/46-20...Q5fAccessories
Trust me I thought about it. After doing the research it was about 175.00 for all the parts not including powdercoating and a bead roll. Yeah I could have compromised and bought the cheaper couplings but I dont want to go cheaper than stock. The tube is tight in there but under high boost couplings have there way of blowing off. Trust me when I had a ford back in the day I was towing up the bishop grade and the factory coupling blew off. It was not fun trying to get that thing back on in the middle of the night.
The material was aluminized not stainless. I would rather just buy it and install it instead of messing around with it.
The factory coupling on the plastic tube has a permanent band that needs to be cut. There is a good chance the coupling will be sliced when trying to tear it apart.
You should have bought a cold air intake for the boost tube to give any real benifit.
Yeah I know its not peak but I notice a significant increase on the bottom end. I already have an aFe mega cannon on my truck.
And yes fords are notorious for blowing off hoses. If stock has it then there is a reason why they put it there. I dont want to be stuck on the side of the road again.
On that graph they have one start at 1,350 and another at 1,600. Of course you are going to make more torque and hp from the run that starts at 1,350, especially when you are taking your reading at 1,750.
I have dynoed some of my hot rods and diesel trucks in the past. I have used a mustang dyno the same one afe used. They set a certain speed range in the specific test gear. They then test both parts. I would consider that an apples to apples comparison. The shift in the curve is the increase in power the part makes.
65pacecar
Sep 28, 2007 02:02 PM
jamesbfishin
Jul 7, 2007 08:25 PM
wap
14
Apr 23, 2007 06:46 PM
one54ton
Oct 16, 2006 02:04 PM
RAMV
Jul 14, 2004 12:08 PM
