5" tbe with bad drone
Just get a 4" system with a muffler. No Drone. If you're really worried about your EGT's, get a better turbo.
5" is not needed until you reach a LOT of HP.
I had the same problem and a vibration, pulled the FloPro alum. and installed the 5" stainless. Never looked back! Think it is the Magnaflow, worth the extra few dollars. Thanks James @RSD for the great service.
FTE diesel also makes a resonator specifically for eliminating this drone and I've read great success. They make a standard size (believe it is 15" or 17") and they make a 30" as a means of replacement for the generic muffler or muffler delete pipe that comes with the 5" TBE. I have an AeroTurbine 5050XL in line on my 5" TBE and it still has much more in cabin noise than I would like so I intend to install the FTE resonator in front of the Aero muffler. I just need to give Wally at FTE a call and see whether he thinks the short one will suffice or if I should try and squeeze the 30" one in front of the Aero.
thaimonkee
03-03-2011 08:15 AM
d_kuda
08-30-2010 09:59 PM
PEAKSTRYDE
10-11-2007 04:20 PM
