3250 dd cermanic not holding
finished some upgrades a few wedeks ago been waiting on a handful of custom tunes go them in last friday went to the track and now the southbend wont hold together past 50 psi mainly in forth and 5th and 6th gear any ideas on where to go from here still a daily driver dont want to go full blow triple disc any ideas thanks
You must be putting down mad torque! Mine handled everything I could throw at it....it was the transmission that couldn't hang!
I assume if you contact Southbend, they could hook you up with a heavier plate/grabbier disk combo?
Do you have the newer dual friction disks or the old ceramic setup?
two year old ceramic style greg at southbend says it will handle 850 hp and 1400ftlb at the wheels and hes not off by to much on the starts to slip at 1497ftlb going to call them back monday blew the throw bearing earlier this week wanted to make sure it wasnt causing the slipping but after replacing it put it back on the dyno still slipped so hopefully they can help me without having to go to extreme to where its not fun to drive on a daily basis
abc4yew
Apr 27, 2006 09:33 AM
Dieseldog800
38
Jan 10, 2006 10:44 PM
