Are you using Geno's Muffler Elimination Kit?
Old Jan 10, 2009 | 08:50 PM
GaCamper's Avatar
I think for now I'm going to leave my Cat in place and delete the muffler. I use my truck to travel & pull a 5th wheel. From what I have found out deleting the Muffler and leaving the Cat I should not get the drone sound when pulling.
Is anyone running the stock exhaust with the Cat still installed and using the Geno's muffler elimination kit?
If so can you give details about the:
Installation? Sound? Performance? Exhaust Temps?
If you have suggestions for another muffler elimination kit I sure would like to hear about it.....Thanks
Old Jan 10, 2009 | 09:09 PM
Evildiesel's Avatar
mine just showed up fri afternoon. Ill have it on monday and let you know!
Old Jan 10, 2009 | 09:32 PM
Big3500's Avatar
I have the Genos muffler delete.
Install: the most difficult part about the entire thing was removing the muffler. I took my time because I wanted to save the muffler for future use if ever needed.
Sound: I think it sounds great. Almost like a big rig truck.
Performance: Did not really feel any performance gains. Probably because my truck is still mostly stock.
Exhaust temps: They probably went down 50 to 100* on the highway. I can't really remember what they were stock, but I do know they went down a little.
I love it. I would do it again in a heartbeat, plus it's a ton cheaper than buying an entire new exhaust. The only thing I did was I bought some band clamps to hold the pipe on better. I did this because using the supplied clamp and the stock clamp for the muffler it would bend the pipe when it was tightened. (Sounds confusing, but I put a band clamp at each end of the pipe, and then I used either the supplied clamp or the factory one and tightened it and attached to the factory hangar). The band clamps are real easy to use, and if I have to remove anything I can without worry.
Old Jan 10, 2009 | 09:37 PM
JCLeary's Avatar
I had one for a while...
Didn't notice any change in exhaust temps, but it did sound louder, a bit harsh maybe?
No major drone, not like I have with the Donaldson M090535.
Old Jan 11, 2009 | 12:00 AM
CRXsi's Avatar
I have the ME kit from Geno's. Personally I love it. Not too loud but a more deeper growl. EGT's are lower but not by more that 100 deg. I tow frequently and have not noticed any annoying drone...
Old Jan 11, 2009 | 01:04 AM
kokalit's Avatar
I used the RPM muffler delete pipe, CAT still installed. Unloaded and not towing anything it sounded really nice. However loaded heavy or pulling 7K trailer I got significant drone. So much so, constantly triggered wife's migraines. I now have a 5"X51" FloPro muffer and do not get any drone at all while towing. The RPM pipe is collecting dust in my garage...
Old Jan 11, 2009 | 09:51 AM
HOBrian's Avatar
I have one and love it. It does drone but at 75+ mph and I don't drive that fast anymore!
Old Jan 12, 2009 | 07:27 PM
Evildiesel's Avatar
Well I Put the pipe on and I cant even tell I did anything from inside the truck except at WOT. No drone in the cab. decent sound at idle. Im happy with it. Took me an 1hr in the driveway. make sure you have a new 4" clamp before you start, they only give you one with the kit.
Old Jan 12, 2009 | 08:04 PM
GaCamper's Avatar
Sounds good. I ordered my muffler delete pipe today. With any luck I'll have it on by the weekend....
Old Jan 12, 2009 | 08:44 PM
jamesbfishin's Avatar
Good reports, thinking of going this route soon myself
Old Jan 12, 2009 | 09:49 PM
rokspydr's Avatar
Did mine last week. Sound's great no drone as of yet as I havn't towed with it yet but it does feel more responsive. I did feel as if it was about 3" too short.
Old Jan 13, 2009 | 11:49 AM
AH64ID's Avatar
I ran that for about 9 months... Entirely too loud when towing. It was very annoying above 2K rpms. Now I run a Donaldson 40" in place of the cat. the Muffler elim kit is still installed. It sounds much better when towing. I am putting a megacab resonator on next week to kill the exhaust brake high freq.
Old Jan 13, 2009 | 12:16 PM
eights88's Avatar
i currently have one on mine and love it a little louder than stock sounds great. I have a habbit of rolling back passenager side window down so that I can here it. Took less that 1 hour. I have mega cab so res helps with drone. Good choice
Old Jan 13, 2009 | 12:33 PM
UNDER-PRESSURE's Avatar
Great sound on Mega cab's with the factory resonator. I actually prefer the sound of my wifes truck over my 5" exhaust.
Old Jan 13, 2009 | 12:40 PM
overcomer401965's Avatar
I have the RPM's but I have ordered the Flowmaster Hushpower Pro Series. I will probably remove the inards out of Garfield and see how it sounds.
