XZT install, big problems, help !!!
Old Jul 18, 2007 | 07:07 PM
svanni's Avatar
XZT install, big problems, help !!! (all fixed now)
XZT, pressure only (DXZT2-S).
All connections are good.
MAP has XZT, then Edge.
Key on, no LED on Quad XZT box. Barely starts, but runs so bad, I shut off immediately. Almost like it's loping at 500 RPM.
Installed bypass plug instead of Quad box. Barely starts, loping at 1200 RPM.
Truck down, need help ASAP.
Old Jul 18, 2007 | 07:12 PM
omaharam's Avatar
Is the pressure plug turned 180 degrees? It will still plug in if it's turned. Not trying to insult your intelligence, but worth a double check.
Old Jul 18, 2007 | 07:13 PM
Luvnacumns's Avatar
have you unhooked it all and tryed to start the truck?? try some dialectric grease on the fittings
BigJohnston's Avatar
You probably shouldn't stack 2 pressure boxes together. I have never heard of an Edge/XZT combo being used by anyone and I am pretty sure it won't work. I am sorry if I am the bringer of unwelcome news.
Disregard I was thinking Edge EZ. My Bad.
Good Luck, Tom J.
Old Jul 18, 2007 | 07:23 PM
cummins dsl's Avatar
check the fuel rail plugs as mentioned before. if you have them in wrong it will not power up the box.
Old Jul 18, 2007 | 07:26 PM
svanni's Avatar
Omaha,
You're a genius. Or I'm an idiot. Or both.
I checked the connection at the rail, but I could only get it to go one way. The piggy-back connection, however, could go either way.
Seems to be fixed now.
Thanks for all the input.
Steve
Old Jul 18, 2007 | 08:14 PM
omaharam's Avatar
Omaha,
Steve
Ok
I figured out what was wrong with your truck, now you figure out what's wrong with mine.
Old Jul 19, 2007 | 10:11 AM
quadman20's Avatar
Ok
Sorry to hear about your truck. I thought they had it figured out. Hope they figure it out soon. Got my new quad box on. Mikey likes.
Old Jul 19, 2007 | 12:28 PM
omaharam's Avatar
Nope. And now Star hotline - the hotline the Dodge techs call into with problems - says they have exhausted all the possibilities and I will have to drive to with the problem until it gets worse.
Old Jul 19, 2007 | 01:38 PM
Luvnacumns's Avatar
Man that's a bummer... Sorry to hear that!!
ClayBob
Aug 7, 2009 09:07 AM
swordfish
Jun 22, 2009 06:52 AM
sCreamin400
Nov 2, 2008 01:46 PM
thxman
14
May 4, 2007 10:00 AM
lwcmattlifter
Jan 6, 2007 01:55 PM
