Xzillaraider II software problem
Just received my X2 race upgrade back from Quad. When I try to run any of the downloads, I get an "application has failed to initialize properly (0xc0000135)" error. Dead in the water from there. Any ideas? Tried on two different computers.
Problem solved
Too excited. Skipped right to download before reading at the top of the Quadzilla download page that .NET Framework must be installed. Did so. HotSmoke is ready to go.
Not Yet.
Tried plugging it in tonight and seems I don't have power to switch. No lights or anything on switch with key on or when started. My original quad race worked perfectly with this harness. Checked voltage on all 4 pins of switch with module connected and don't get anything. Unplugged everything and checked voltage. Should I have 12V somewhere because all I get is 5V on a couple pins and 2.5V on a couple others? I'll check in the morning (daylight) to make sure I don't have something hosed up and check all under-hood connections but like I said, my original quad race was working fine on this harness and I haven't touched it other than to plug the X2 in.
Ya had same thing on my wife pc, error code wise. Thought .net stuff loaded but was wrong but success the second time. Can not get it to work with Vista at all go wont find module, not sure why everything else works the same on the screen as wifes pc w/XP.
I plugged the X2 Race back in today. No display at all on the switch. Checked all under-hood connections. Nothing seems out of the ordinary. I removed the module and checked voltages on all pins with the key on.
P1 = 5V
P7 = 0.5V
P8 = 5V
P9 = 1.2V
P11= 2.5V
P12= 2.5V
Pins 2-6 and 10 have 0V. Any ideas Quad?
P1 = 5V
P7 = 0.5V
P8 = 5V
P9 = 1.2V
P11= 2.5V
P12= 2.5V
Great Quadzilla Service
Another "Atta Boy" for Quadzilla customer service. The harness I had ended up being an old version that didn't work correctly with the X2. Quad and Jeremy helped me get the harness re-wired correctly to work with the X2. Could have easily spent weeks sending items back and forth with other companies. Tried the HOTSMOKE tune first on the lower settings (still have OEM clutch). Didn't notice much smoke but power was smooth. Went to MPG tune and tried all settings. I ran my original Race on the 65Hp setting most of the time. The 65HP setting on this X2 feels closer to the 100HP of the original. I'll be able to really wring it out when I go hunting next week. Great job guys.
DRM
38
Jan 8, 2009 08:22 PM
usmcduncan001
Sep 14, 2007 04:10 AM
riversidediesel
14
Feb 28, 2007 11:06 PM
mbenedict
Sep 8, 2005 10:39 AM
Hal
May 1, 2005 06:24 PM
