Would Willys Whistler cause intake restriction?
Old Feb 4, 2008 | 07:56 PM
sallyman1's Avatar
Would ****** Whistler cause intake restriction?
Could ****** Whistler homemade filter cause too much restrction versus stock air box? Reason being is i added ****** whistler the same day i added the edge juice attitude. now i see HIGH EGTS and LOW boost (23 psi)max. Edge told me its got to be my turbo or air leaks? Even on setting 0 stock i can see egts as high as 1400F. Edge asked me what kind of filter i had.
The thing is I know ****** Whistler isnt as pretty as a AFE stage 10 or whatever, but what restriction do u think it has? It has to be better than stock right?Would it be the blue amsoil prefilter sock on the intake restricting my filter?
Old Feb 4, 2008 | 08:55 PM
sallyman1's Avatar
any1. I often wondered about the way it connects to the stock 4" elbow
Old Feb 4, 2008 | 09:11 PM
sallyman1's Avatar
any1? I mean i dont want to sound stupid but it should be better than stock right? Would the MASS flow sensor be out of wack now due to the increased air flow causing high egts?
Old Feb 4, 2008 | 09:13 PM
cbrahs's Avatar
no MAF. it is intake air temp. it would not create any restriction unless the filter was dirty. you are increasing diameter of tubing. did you gut the x out of the straight tube and kill the white thing out of the elbow?
Old Feb 4, 2008 | 09:20 PM
cbrahs's Avatar
have you checked all of your intercooler boots for any tears or loose connections?
Old Feb 4, 2008 | 09:45 PM
sallyman1's Avatar
yes i checked all boots. i tore out all white stuff except elbow because it kinda guides air into turbo.
Old Feb 4, 2008 | 09:48 PM
dropped2500's Avatar
good point, maybe mine will find its way back home
Old Feb 4, 2008 | 10:50 PM
53 willys's Avatar
My egts have been fine for over a year with that intake....the ONLY difference is yours has the amsoil pre filter..but I highly doubt that is the problem...I think EDGE is your problem........have you taken the edge off your truck completely??? unplugged it completely???I have not even cleaned my filter since I installed it and my EGT's fine...sell the edge and get a Smarty
lineman joel
0
Apr 22, 2010 07:37 PM
sallyman1
Mar 14, 2009 12:02 PM
jasonstacked06
15
Dec 11, 2007 11:37 AM
proworks1
Jul 11, 2007 11:58 AM
DodgeDemon
Jun 27, 2007 10:14 AM
