Won't start
Old Apr 19, 2008 | 05:45 PM
SINGLESTACK's Avatar
Won't start
Came back from the drag strip last night and slowed down at the light and the truck started idleing like a cammed up 12v blowing white, blue, and black smoke, got to the house shut it off and went to mess with it this morning and it won't start. Fuel filter looks fine and there are no codes. Also there is no fuel in the oil and I drained the water from the filter housing. Thanks for any comments.
Old Apr 19, 2008 | 08:29 PM
matego's Avatar
madhat's monkey boy...
Did you check your oil for fuel yet? Doesnt that dual line kit do away with the relief valve? Do you have any way to check your rail pressure? Sorry for all the questions but there are a couple of things it could be. Do you have a modded CP3, FCA?
Old Apr 20, 2008 | 09:23 AM
No fuel in the oil , I have not modded the cp3 and I took the dual line off I think I'll try to get me a scan tool today and crank it and see what that says.
Old Apr 20, 2008 | 09:38 AM
jrussell's Avatar
Sounds like injector issues to me. You probably have a sticking nozzle (or two).
Old Apr 20, 2008 | 11:48 AM
I thought it was a injector also but there is no fuel in the oil
Old Apr 20, 2008 | 12:01 PM
matego's Avatar
Your injector may not be cracked into the crankcase but hanging open. If it is open you will not be able to create enough fuel pressure to start it. If you could check with a scan tool to see what the rail pressure is, you would know where to go with your starting problem.
Old Apr 20, 2008 | 12:04 PM
yea I hope thats what it is I will get a scan tool tommarow. thanks guys.
Old Apr 20, 2008 | 02:38 PM
jrussell's Avatar
Yeah like Matego said, nozzles can stick open (and I assumed closed as well?) and fuel won't leak into the oil.
Subliminal
Dec 15, 2010 04:35 PM
ado2b1
Dec 16, 2008 03:19 PM
Machinos
Mar 16, 2008 01:34 AM
