will this wheel and tire combo fit????
the wheel is 20 x 9 with a 30mm offset that is about 6.25" of backspacing. with a toyo mt 35 x 12.5 x 20 tire. This is going on a leveled 06 Mega 2500.
thanks for the help
thanks for the help
Nope. Well, the overall diameter is the same but that's it. Here's what I have:
17x9 with 5.71" b.s.
325/70-17 (35"x13") Toyos
The wheels you spec'd are 1/2" wider than stock with 10mm less offset, which puts the outside edges (inside and outside) about 1/4" further away from center. 35's on the factory wheels rub the control arms at steering lock. So those will rub a little sooner.
You're right. Stock wheels are 8" wide. I had H2's on the brain. So those wheels will stick out about 0.9" more than stock. I'm tired, so I may be botching the math right now.
PowerDiesel44
Mar 8, 2008 09:17 PM
signature600
28
Jul 17, 2007 03:43 PM
Jmac
Feb 25, 2005 01:16 PM
hooked3800
28
Aug 26, 2004 01:13 PM
cummer01
May 26, 2004 02:20 PM
