Will I definitely notice a better turbo?
Old Nov 27, 2007 | 09:47 PM
jmccart's Avatar
Like it says. Would I definitely notice more power with a better turbo, like a 62/14?
Thanx.
Old Nov 27, 2007 | 09:51 PM
OldSmokey's Avatar
I noticed lots more with my 66. With my stocker it would set you back in the seat but seemed to let off with more RPM, but with the new turbo it just keeps pulling more and more!
Old Nov 27, 2007 | 11:22 PM
Woodchuck61's Avatar
I got a 62/14 and it flet like it added 50 HP and it pulled strong all the way up to 100 mph.
Old Nov 27, 2007 | 11:27 PM
templer's Avatar
If you go with the 62 you will be happy with it in my opinion. I have one and I tow with no problems. Egts are nice and cool and pulls strong. I get around 41 psi. So no need for studs.
Old Nov 27, 2007 | 11:31 PM
skynyrd's Avatar
thing is with the stock turbo once you get above 30 psi its just not pushing the air efficiently the bigger turbo will help with this and causes better pull and power on the top end but going to big will hurt you on the lower end with spool so you have to balance it out for what your planning to do. but a 62/14 seems like it would be a good turbo for what you have. not sure about the superchips but with a smarty or ppe or edge juice you could do a 64/14
Old Nov 27, 2007 | 11:51 PM
RamNu2's Avatar
I had a 62/14 on till the other day and loved it just big enough to not notice with spool up but more efficient that stock to definately feel the top of the rpm range. I now have a 66 on and with no extra fuel it is slow to spool if at all with out a lot of pedal.
Old Nov 27, 2007 | 11:58 PM
skynyrd's Avatar
ramnu2 sounds like its time for some sticks for you!
Old Nov 28, 2007 | 12:00 AM
jmccart's Avatar
Thanx for all the info guys. Quality information.
Old Nov 28, 2007 | 01:35 AM
SlowSixSpeed's Avatar
I have a 03 that has a smaller then 04.5+ so its pretty lame, anyways I have Smarty and found a good deal on a used Silverbullet for $1,400. After the install I wasnt impressed at all. I was expecting alot more because my stock turbo was really small. Felt like maybe 25 extra hp. Talked to a friend and he said I needed to add pressure via MP8. Well that sure cured my problem. It added alot more seat of the pants power and an extra 50hp on the dyno.
This turbo will make a big difference in hp/tq as long as you add a pressure box. I like the power and adjustability of the MP8.
You will be dissapointed if you dont add pressure.
Old Nov 28, 2007 | 06:43 AM
wap's Avatar
wap
To me upgrading the turbo is more for decreased EGTs so you can run more fuel, therefor make more power. You should gain power with a larger turbo but that alone doesnt justify the cost to me. Just my 0.02.
Old Nov 28, 2007 | 07:06 AM
ImpulseHydro's Avatar
62/14, 66/14, who is a good supplier of these turbos?
Thanks.
Doug.
Old Nov 28, 2007 | 07:11 AM
tcr's Avatar
tcr
Thanks.
Doug.
Call Vulcanperformance.com, talk to Eric. Best prices I've found and they advertise here!
Old Nov 28, 2007 | 10:21 AM
jmccart's Avatar
Here is what I was following on e-bay. I have decided to pass. It is new and starting bid is $995.
http://cgi.ebay.com/ebaymotors/ws/eB...181631266&rd=1
Old Nov 28, 2007 | 10:36 AM
ptgarcia's Avatar
Thanks.
Doug.
Member "lmills" (Lloyd) here on DTR is a reseller and spent a lot of time helping me chose the right turbo then quoted me the best price. When I'm ready I'll be calling him.
www.midatlanticdiesel.com
Old Nov 30, 2007 | 01:07 AM
Thanks for the info guys.
I have a Jacobs Exhaust Brake, I hope that will not be an issue in going to a different turbo.
Doug.
