will bigger tires make truck shift later?
Old Oct 16, 2009 | 08:27 AM
HOV's Avatar
HOV
When I put on my 285/75's, I reprogrammed the tire size with Smarty Jr. The truck still shifts at higher speeds.
However, this may be due to the DTT Shift Enhanser I installed the next day...
I like the higher shift points. It makes OD lockout a no-brainer in city traffic, whereas that setup was a little frenetic before. It makes 2nd taller - comfortable up to the mid-30 MPH range - and 2nd is important when towing heavy with a trans with only 4 gears.
Old Oct 16, 2009 | 02:11 PM
MTC's Avatar
MTC
So, let me see if I got this right?
I just put 285/75's on my truck, and the rpms are very low compared to where I was with the stockers. So low on the highway that it feels like a turd now. Will the truck shift and drive better if I change the tire size with the Jr. back down to a stock size tire?
Old Oct 16, 2009 | 02:28 PM
sloride's Avatar
MTC, you wanna change it to the new tire size so that the speed you are seeing on the speedo is the correct speed. Our trans shift points are determined by speed. I assume the 07's are the same as the 04's and up.
Old Oct 16, 2009 | 02:33 PM
MTC's Avatar
MTC
Immediately after mounting the tires, I corrected the size with the Jr....The rpms just seem to be too low now
I mean, I knew the taller tires would affect the rpm's, but not this bad
Old Oct 16, 2009 | 02:48 PM
sloride's Avatar
Those tires are only 33" tall(almost 34) so it really shouldn't make that much difference going from stock. Did you check your speed with a GPS after you adjusted for the tire size and make sure your speedo was correct? Sounds like it may be off.
Old Oct 16, 2009 | 03:15 PM
MTC's Avatar
MTC
No, I havent checked with the GPS...Ill do that tomorrow and see whats up.
Before the taller tires, my rpm's @ 70mph were right around 2K. Now @ 70 mph my rpms are 1650-1700...It just seems like a turd there.
Old Oct 16, 2009 | 03:29 PM
sloride's Avatar
I have 4.10's so I have no idea where your RPM's should be.....sorry.
Old Oct 16, 2009 | 03:53 PM
WhiteMule's Avatar
I calculated that you should be at 1788 rpms using 33.86" tires @ 70 MPH.
Check your speedo.
Old Oct 16, 2009 | 04:15 PM
MTC's Avatar
MTC
Thanks Mule, Im going to check with my GPS and see whats up.
Old Oct 16, 2009 | 05:09 PM
WhiteMule's Avatar
Try this http://www.csgnetwork.com/multirpmcalc.html
Plug in .69 for OD, 1.00 for Drive.
cLAYH
Jul 28, 2013 11:07 AM
CODODGE2500MAN
Apr 19, 2010 12:05 PM
1320
May 29, 2009 10:24 PM
sakisaki400
23
Dec 31, 2006 10:17 PM
DF5152
Oct 21, 2003 03:51 PM
