wild smarty and southbend hold test
Old Dec 28, 2006 | 11:20 PM
dodgezilla04's Avatar
Originally Posted by drodgers
Well??????
505, 1021. pretty happy with those numbers. heres the link to the video.
http://video.thedieselgarage.com/vid...a30134194e.htm
Old Dec 28, 2006 | 11:41 PM
Luvnacumns's Avatar
Awesome Vid......
Old Dec 29, 2006 | 12:17 AM
thanks, the vid quality is improving, but not nearly as on par as some of the other fellas. having fun with it though.
Old Dec 29, 2006 | 05:22 PM
gus's 03's Avatar
any shots of the torque curve /plots ?
Old Dec 29, 2006 | 05:30 PM
Robert P's Avatar
does your truck still have stock injectors and cp3?
also any runs on sw9 at all?
sweet video by the way.
Old Dec 29, 2006 | 06:20 PM
stock injectors and cp3. no rail draining trouble is evident. but the dyno runs are only about 8 seconds at wot.
no runs on level 9 until i get studs. level 9 increases timing advance, which increases cylinder pressure, on top of that I run about 47 psi of boost, i dont want to lift the head, so until i get studs, no level 9. i will have it done before the BD dyno day in the spring, so i will have new numbers then.
the dyno sheet doesnt show the last run, which netted the 505/1021. just the 500.3 hp run of quad on 100, smarty on 8
Old Dec 29, 2006 | 06:23 PM
wap's Avatar
wap
Would you run sw9 with no quad or do you think that would still be too much?
Or has the timin been deleted off your quad?
I would think any odd number smarty with a normal version quad race would be too much timin.
Old Dec 29, 2006 | 06:26 PM
i wasnt too worried about the quad, the smarty timing combined with my boost pressure made me nervous. i will flog it royally when i install studs. smarty level 9, quad on max, and wastegate set to 55psi. then we'll dyno again
chrigu
Jul 17, 2007 05:47 PM
D.Wiggs
36
Jan 2, 2007 04:10 PM
BlackBeast
Dec 31, 2006 12:26 PM
