Who's over 600hp with a smarty
Old Aug 13, 2007 | 03:25 PM
jlibert's Avatar
Stacked or not, who's making 600+ using a smarty as part of the equation. what setting do you run on? What program? If your sig doesn't show your mods, make sure to list them. thanks.
Old Aug 13, 2007 | 03:27 PM
dodgezilla04's Avatar
a friend from NW diesel dyno'd saturday at 675 and the rollers were being stingy. lets see. smarty beta, tst 1X0, edge ez level 2. IISPS 62/14/s400 twins, studs, II stage2 Cp3, 90hp sticks, dual feel line, fass, single stack.
Old Aug 13, 2007 | 04:36 PM
2003Ram's Avatar
I would say Smarty was a small part of that equation.
Old Aug 13, 2007 | 04:46 PM
uh, smarty made a large difference. we played with many variables. the dyno was being very very stingy. its an inertia dynojet.
Old Aug 13, 2007 | 04:58 PM
cquestad's Avatar
Lots of people...
Llyod Mills...750 or something with Smarty, Injectors, and Pump.
Smarty is a great platform!
Old Aug 13, 2007 | 06:01 PM
2003Ram's Avatar
I know what Smarty can do.......I have one. But you have TST, Edge, fueling, injectors, and twins. You should be close to 600 or more without Smarty.
Old Aug 13, 2007 | 06:18 PM
demon1's Avatar
i am with whats in my sig!!
Old Aug 13, 2007 | 06:34 PM
omaharam's Avatar
I know Sloverado was with a 66, Flux 3.5s, stage 2 pump, and an EZ. Don't know what his current set up is, but I'm sure it involves a Smarty.
Old Aug 13, 2007 | 07:40 PM
GOT BOOST?'s Avatar
I hope to be over 600 with my setup, I am currently getting some head work done and o-rings, I hope to dyno some time soon. Jay
Old Aug 13, 2007 | 08:36 PM
D.Wiggs's Avatar
I am in the bazillion HP range with a Smarty. I run #9 99% of the time except for really heavy towing in mountains when I go to #3 to keep EGTs lower.
Old Aug 13, 2007 | 08:40 PM
OT-OF-Here's Avatar
Smarty
Like CQuestad said,.. it's a great platform for 600 and up. I'm well over now but no one should tell everything.
Old Aug 13, 2007 | 09:10 PM
lmills's Avatar
with the recent add ons, I will have to hit the dyno to see. On a single pump, twin turbos, Sp diesel pressure box, Don's sticks and the Smarty, I dynoed 700 HP even. With the water/meth I did 768 and 756 HP.
I am quite sure I have surpassed that point. I will get some new numbers in about 2-3 weekss.
Old Aug 13, 2007 | 11:48 PM
Rob C's Avatar
How much Meth were you running to get those numbers?
Old Aug 14, 2007 | 12:01 AM
ramtd02's Avatar
I am @ 650-700 on #2 only.
Old Aug 14, 2007 | 12:02 AM
Sloverado's Avatar
With a the Beta 4.2 Smarty alone with my mods I have put down over 625+ alone(not saying actual #'s because of pulling saeson). That is with stock cam, single turbo, one Floor It pump. I run a stack when I pull that helps even more. Also with the tripple stack I lost power turning the TST on! Yes Omaha Smarty has is in it and is going to stay.
