Who wants some Juice?
I just saw Extreme Diesel Performance's website. It says Edge Products will begin shipping the Juice and Attitude Monitor for 04.5 and 05 in three days and they are taking orders now. It does say to call for pricing.
Now can beta testers tell us what they know about these products?
I've been waiting on Edge and been considering a TST before I buy gauges or anything. I thought the look of the Attitude monitor was more modern and would look better in the truck than the TST. I won't give up a great deal of performance just for a better looking piece though.
Any Guinea Pigs out there?
Originally posted by Got Juice?
Trust Me.... You want the Attitude...
Fast reading Pyro.
More adjustability for smoke settings and power levels.
Fast reading Pyro.
It sure would be nice to know what the hook up is like for the Juice. IOW- is it simple like the EZ or more complex like the TST? For me in the short term an easily removed Juice+EZ combo with my own gauges would be ideal.
It doesnt have the crank/cam sensor harness like the TST does,
So, if they're really doing that (ie. beginning the injection event on their own, based on RPM), then that would eliminate the spurious P0336 codes we TST users get from time to time, but it also explains the much longer development time, since that seems to be a more complicated (ie. problem-prone) approach to take.
Originally posted by Tom488
How can it advance injector timing without intercepting the signals from these sensors?
.......it can't. It would appear that they may be squeezing out a few degrees advance from a custom map program like the RAMifier does with it's low boost fooling. If that is the case, then it doesn't "do" timing like we were expecting. Just gets you a few degrees advance when you really get on it...nothing at cruise. Hopefully there proves to be more to it than meets the eye, because if everyone waited this long for a VA C3.2 with RAMifier mapping, what a disappointment.
The juice also plugs into the data link like the 6 gun
Do they just have one connection there, or are there two big connectors? The crank signal is on one of the 60-pin connectors, the cam signal is on the other.
What data link?
What data link?
These monitors show a lot of fancy sensor readings, like MAP pressure, coolant temp, oil pressure, fuel rail pressure, etc., and they get it all from the datalink port. One simple plug gets you lots of data, but the signal is one way and doesn't go back to anything, so it can't be used to manipulate a reading such as timing....if I remember correctly. The Outlook Monitor plugs into it for all of it's readings as well, except for pyro.
