who makes a 4" stainless turbo back exhaust for an 06'??
Old May 15, 2007 | 05:25 PM
Ghost Ram's Avatar
i know i can use what i already have, just want to know if anyone makes a complete turbo back for an 06'?
Old May 15, 2007 | 05:38 PM
$oC@l CTD's Avatar
Silverline, MBRP, Magnaflow...couple others...
Old May 15, 2007 | 09:41 PM
Ghost Ram's Avatar
i have only found a MBRP cat back for 06'. i will check silverline, are they any good?
Old May 15, 2007 | 09:57 PM
53 willys's Avatar
Hog exhaust... comes with 6" tip
Old May 15, 2007 | 10:11 PM
Ghost Ram's Avatar
i checked out silverline and it looks like they make a nice exhaust at a great price. anyone know how they sound?
Old May 16, 2007 | 08:24 PM
phloop's Avatar
MBRP does make a 4" turbo back system for your '06. You just need to but the system for the '03-'04. I just went through this when I put the Cool Duals on. I ended up just going cat back, now I wish I would have removed the cat.
Old May 16, 2007 | 08:45 PM
$oC@l CTD's Avatar
http://s165.photobucket.com/albums/u...t=DSCF1879.flv
http://s165.photobucket.com/albums/u...t=DSCF1880.flv
http://s165.photobucket.com/albums/u...t=DSCF2137.flv
Here are a few clips of my turbo-back Silverline...pretty easy install too...invite over a friend and get some beers...
Old May 17, 2007 | 10:10 AM
JThiessen's Avatar
Any issues at all with installation?
The video sounded like it wasnt too loud - is that an accurate take on it?
Old May 17, 2007 | 10:44 AM
jwb600's Avatar
ive heard mbrp 4" system on an 06 it was pretty quiet. it was a little louder than stock. I installed this system on an 01 it was very quiet inside and the kit fit was cake to install. I would consider mbrp it is quality exhaust.
Old May 17, 2007 | 11:56 AM
ScienceOfSpeed's Avatar
Rolling Big Power makes a nice stainless exhaust kit
Old May 17, 2007 | 01:03 PM
$oC@l CTD's Avatar
No, it's not very loud...throaty and decently loud when you're mashing on the skinny pedal, but during normal acceleration, idle and when you flatten out your speed, it's pretty quiet. That is one of the main reasons I bought it. I drive a LOT and a LOT of my driving is on the highway and I would drive myself crazy if I had droning a lot on the longer trips. Even pulling 8-10k once the acceleration flattened out, I didn't have any drone.
The install was pretty simple. The only issue that I ran into (turned out to be nothing at all) was that the first hanger piece (tranny mount) didn't fit, so I took the rubber stock piece off altogether and mounted the rest without it. Also, the stainless steel pieces will slide apart after a while no matter how hard you torque them down (I'm assuming MOST are like that if not all of them) so I hammered them together from the back, spot welded where the pieces connect and welded a washer onto the tip of the last hanger just to make sure that it doesn't come out while I am offroading.
Old May 17, 2007 | 01:17 PM
timber's Avatar
I bought a MBRP a catback system with a catalytic test pipe. Ended up leaving the cat on - didn't want the truck much loader than stock. Got a couple Harley's for that!
Old May 17, 2007 | 03:11 PM
MBRP TECH 3's Avatar
Hi Ghost Ram you find mostly cat back systems because the stock Down pipe is already 4" mandrel bent to the cat.
you can also get a cat delete pipe if you want maximum power & lower egts
Old May 17, 2007 | 03:16 PM
$oC@l CTD's Avatar
His truck has a 3.5" system and from the factory doesn't have a cat...
Old May 17, 2007 | 03:22 PM
ptgarcia's Avatar
Check his sig again, Derek. He has an '06.
