Who Has A K&N Intake Kit?
Old Dec 14, 2007 | 12:13 PM
D45's Avatar
D45
I am curious who has the 57-1532 intake kit. What do you think of it?
I am looking for input on how good the kit itself it made, like the heat shield, the intake tube, and the overall fit and finish of the kit. Any problems or info?
I am not interested in the filter, at all. I am not looking for answers like, "Their filters are junk"....cause I know they are poorly made.
I have the chance to buy an intake kit, for VERY cheap. My plan would be to replaced the stock filter (RC-4780) with an Amsoil Ea Series cone filter, either the EAAU-4090, EAAU-4091, or the EAAU4095.
I had an K&N FIPK kit on my 2004 Dakota Quad Cab 4x4 with the 4.7L V8, and thought it was a very well built and constructed kit.
Thanks for any and all info!
Old Dec 14, 2007 | 12:18 PM
Rob C's Avatar
I have the FIPK on mine and replaced the filter with a 4095 and it has worked flawlessly since I installed it, it took about 30 min to install. My only wish would be that the tube was bigger.
Old Dec 14, 2007 | 12:42 PM
D45's Avatar
D45
What size is the tube, 4"?
Also, what is that little crankcase-like breather (mounted on the heat sheild)I see on various pictures of this intake kit?
Old Dec 14, 2007 | 03:49 PM
Rob C's Avatar
Yeah, it's 4 inch. The air sensor that is in the stock tube goes in the mini breather.
Old Dec 14, 2007 | 11:43 PM
D45's Avatar
D45
Do you think a larger filter, that the 4095, can fit into the area within the heat shield?
Old Dec 14, 2007 | 11:53 PM
matego's Avatar
madhat's monkey boy...
I dont know why everyone cuts down on the K&N filters. I have found that keeping it correctly maintained has shown on my oil samples to be more than adequate for filtration. I dont want to start the whole K&N is junk debate, but a couple of years ago, it was the best and nothing else came close.
Anyway, I really did not like how the alternator bracket fit on my FIPK and I think the heat shield could be supported a little better, but all together a pretty good set-up.
Old Dec 17, 2007 | 11:09 AM
Rob C's Avatar
you might be able to get a bigger one in, but the 4095 is a nice fit, and you don't have to fight it to get it in or out.
Old Dec 17, 2007 | 11:12 AM
Rob C's Avatar
Most don't like the K&N because the turbo can/will suck the oil out of the filter and can/will damage the the turbo, had I known this before I bought mine, I would have never bought it.
Old Dec 17, 2007 | 11:18 AM
CTD03's Avatar
I have i have the tube and amisoil filter works awsome
Old Dec 17, 2007 | 12:11 PM
jmccart's Avatar
I have it. I just removed the K&N cone filter and added an Amsoil Eaau 4091. It pops right in.
Old Dec 17, 2007 | 01:32 PM
Hounddog's Avatar
Lots of AFE oil filters on these trucks.Its a oiled filter.Never have seen or fault oil in my intake tube or on turbo fins.Its in how MUCH oil you put on the filters.A little goes a long way.
Old Dec 17, 2007 | 08:36 PM
matego's Avatar
I know when I oil my filter, I use the aerosol can and a very light coat. Wait about 1hr and look for any white or very pink spots and lightly hit them again. I even tried the trick of putting a dab of grease in my intake tube because everyone said they suck a lot of dirt. After 25k with it on, no dirt on the grease. Then everyone said there would be oil all over my compressor wheel. After 25k you can still see bare metal and even the paint on the one fin from the factory.
Its all in how you maintain your set-up. Everything I have owned from ATV's, cars, trucks etc. have always got the K&N and none of them blew up or spontaneously combusted.
Since all of the K&N's are such junk, I will give out my address and I will pay postage to have them mailed to me. I will use them.
Old Dec 17, 2007 | 08:43 PM
Wild04.5's Avatar
i *HAD* a K&N air intake on my truck... didnt like it..
replaced it with a AFE stage 2 with the Pro-guard 7 filter..
truck runs ALOT better..never looked back at that point.
Old Dec 17, 2007 | 08:52 PM
Billm2004's Avatar
exactly, a lot of people tend to over oil it
Old Dec 17, 2007 | 10:51 PM
Hounddog's Avatar
I bet away from these sites K&N is the biggest seller of aftermarket/performance filters that the public buys.
