Who has changed the "out" pipe on their turbo?
Who has changed their "out" pipe on their turbo for better economy and more flow? Can you use "off the shelf" or "self fabricated tubing assemblies" to make the air flow better and get better boost therefore better mileage? I heard something about a newer turbo outpipe or downpipe for my 03 HO that can be changed easily that will get mileage gains. Thanks y'all!
Note: My Turbo IN is excellent, I need "out" or "downpipe" help, only thanks!
You can find a used elbow off of a 04.5-07 5.9, it is a full 4". As for downpipes, MBRP offers one, or any of the exhaust brands for that matter. You need a full 4" downpipe, then you'll be good for anything you want to throw at it.
The stock muffler is the biggest problem - it's only 3" inside. I couldn't tell any difference at my power level when I went from 3.5 to 4 on the elbow and DP. Craig
In your opinion if one is not looking for large power gains it is fine to leave the 3.5 exhaust and just get a new muffler?
I did all my mods, one step at a time and I did the DP/elbow last and didn't see a noticeable decrease in egt at full load (towing) and full throttle on 100 hp. I also firmly believe that no two trucks are identical so it may work better for the next guy. It does look nice, tho! FLASH, now that I think about it - I added the glasspack/resonator (between the DP and 51" nelson at the same time - SORRY! So it did help a little cuz I now have two mufflers and no higher egt than with one muffler and the 3.5" DP. I'm still glad I built my own and saved some bucks cuz the improvement is small. Craig
95black2615
10-04-2008 12:29 AM
capnp72
06-08-2008 12:45 PM
GUMP
05-26-2008 08:26 PM
maddog madden
25
12-12-2007 05:36 AM
